Need to load a 16.0 KB bin on a 27SF512 (64.0 KB) prom...are basic instructions available using TP RT Bin Stacker?
BIN Stacker help
Re: BIN Stacker help
See the 'Bin Stacker' section under the 'Index' tab of the Tunerpro help file.
If you do not want to stack binaries then see the 'AutoProm PROM I/O' section for the offset to use when programming.
Thanks for the reply..didn't realize there was that many help topics right inside TunerPro!
May sound like a dumb question...but wouldn't be easier to just use a 27C128 chip versus stacking a 27SF512?
BTW: The "bin stacker" demo screenshot in the instructions doesn't match the 5.0 release screenshot. Couple extra boxes....think I figured it out.
Are there instructions for using the Block E option? When do you check this block?
- stackerC.jpg (66.19 KiB) Viewed 9358 times
