Checksum Recalculate
JP86SS
Post by JP86SS »
Hi Mark,
I found something you may have run into in the past.
When making changes to the VE tables with "software" (VEMaster, etc)
I would burn the chip and forget that the checksum was not recalculated unless edited in TP.
A menu item to do a checksum confirmation would be good to have.
Right now I just make a change and the change it back to get the checksum to recalculate. Only took me a few chips to figure out what happened but was easily reconized (when you think about what you've done)
Then all is good. :D
JP
Sure, I can do that.
Also note that all you have to do is open the bin in tunerpro (with matching ECU) and hit save. You shouldn't need to make any changes.
thanks!
