I found something you may have run into in the past.
When making changes to the VE tables with "software" (VEMaster, etc)
I would burn the chip and forget that the checksum was not recalculated unless edited in TP.
A menu item to do a checksum confirmation would be good to have.
Right now I just make a change and the change it back to get the checksum to recalculate. Only took me a few chips to figure out what happened but was easily reconized (when you think about what you've done)
Then all is good.
JP
