Who Needs An ADS or ADX?
i've got time on my hands and have been slowly adding to the list on the site, but i don't know what people want/need.
- info2.phtml
- (19 Bytes) Downloaded 20 times
i found something, but its not the most reliable info...
http://www.lotus-carlton.fsnet.co.uk/aldlmode0.htm
http://www.lotus-carlton.fsnet.co.uk/ALDLMODE1.htm
i can get MOST values into the ADS...
but according to the site, i don't know if TPV4 can do it. technicly you could probably use the quick-send button to send the mode 0 to "wake-up" the ECU and then connect...
well, i'm off to make a ADS...
since the hot topic of the year is that TPV5 is built on the scannerpro engine, then yes i assume it would(assuming you set up the macros correctly), but i still think i can get it to work with V4...dex wrote:I think the message starts with 0xF0 for the $74 Lotus ecm. I also had a quick look at the Lotus Carlton Mode 1 data and it does not tie in with the data I have in the F95 table.
If TunerPro v4 cannot handle the comms, would ScannerPro?
give me some time(maybe another hour) and i'll have it done, and feel free to test it
right, it is $EE. V4 has problems with it though so i can't gurantee it will work... but is it an auto or manual and LT1 or LT5?dizwiz24 wrote:Im looking for a definition file for a 93 corvette for tuning with TunerPro RT.
The information on my stock ECM reads as follow
BAFL
16173861
I was told something about needing a EE file.
Information on the chip itself reads:
(sticker on chip)
Delco
5224
3050
(sticker on chip casing)
BAFL
3867
Vindicator
Vindicator
Hi
Is this something you could do?
SPECIFICATIONS FOR DATA STREAM INFORMATION
ENGINE USAGE:
3.8L SUPER CHARGED L67 (VIN = 1) 1992 PONTIAC H-CAR
3.8L SUPER CHARGED L67 (VIN = 1) 1992 2,3C - CAR
3.8L L27 (VIN = L) 1992 1,2,3 U van
* 3.8L SUPER CHARGED L67 (VIN = 1) 1993 PONTIAC H-CAR
* 3.8L SUPER CHARGED L67 (VIN = 1) 1993 2,3C - CAR
DATA PIN: READ DATA ON PIN "M" OF ALDL CONNECTOR
BAUD RATE: 8192
This is a GMP4 FULL - FUNCTION ECM.
MODE 0 (RETURN TO NORMAL MODE)
ALDL REQUEST:
- MESSAGE ID = $F4
- MESSAGE LENGTH = $56
- MODE NUMBER = $00
- MESSAGE CHECKSUM
ECM RESPONSE:
NORMAL MESSAGES
MODE 1 (TRANSMIT FIXED DATA STREAM)
ALDL REQUEST:
- MESSAGE ID = $F4
- MESSAGE LENGTH = $57
- MODE NUMBER = $01
- MESSAGE NUMBER = $00
- CHECKSUM
THE ECM WILL RESPOND WITH THE FOLLOWING MESSAGE:
- MESSAGE ID = $F4
- MESSAGE LENGTH = $96
- MODE NUMBER = $01
- DATA BYTE 1
- DATA BYTE 64
- CHECKSUM
MODE 7 (COMMAND MESSAGE NORMAL MODE MESSAGE)
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $07
- MESSAGE ID = $45, $4A, OR $F0
- CHECKSUM
THE ECM WILL RESPOND WITH THE REQUESTED WITH NORMAL MESSAGE
MODE 8 (DISABLE NORMAL COMMUNICATIONS)
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $08
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $08
- CHECKSUM
..PAGE
MODE 9 (ENABLE NORMAL COMMUNICATIONS)
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $09
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $09
- CHECKSUM
MODE 10 (CLEAR MALFUNCTION CODES - TESTER TO ECM)
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $0A
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $0A
- CHECKSUM
..PAGE
NORMAL MODE MESSAGE SCHEDULE TO BE INCLUDED IN THE MODE 1 8C COMMAND
MASTER MODULE NORMAL MODE MESSAGES TO BE COMMANDED DURING MODE 1
COMMUNICATIONS WITH ANY CONTROLLER ON THE DATA LINK WITH THE MASTER.
THESE MESSAGES ARE TO BE COMMANDED WITH A MODE 7 COMMAND.
COMMAND ID LISTEN ID MES LENGTH
$4A $4A x ECM BROADCAST MESSAGE
$45 $45 X ECM BROADCAST MESSAGE
COMMAND ID: THIS IS THE ID OF THE NORMAL MODE MESSAGE TO BE COMMANDED BY A
MODE 7 TO THE MASTER.
LISTEN ID : WHEN THE MODE 7 IS SENT TO THE MASTER, THE MASTER TRANSMITS THE
REQUESTED NORMAL MODE MESSAGE WHICH MAY OR MAY NOT CAUSE A
RESPONSE MESSAGE TO BE GENERATED BY ANOTHER MODULE. IN ORDER TO
MAINTAIN PROPER SYNCHRONIZATION WITH TRAFFIC ON THE DATA LINK, THE
LISTEN ID SHOULD BE THAT OF THE RESPONSE MESSAGE IF ONE IS
GENERATED OR THE COMMAND ID IF NO RESPONSE IS GENERATED BY THE
NORMAL MODE MESSAGE.
MES LENGTH: IF THE RESPONSE MESSAGE ID IS THE SAME AS THE COMMANDED MESSAGE ID
THE MESSAGE LENGTH IS USED TO DIFFERENTIATE THE RESPONSE MESSAGE
FROM THE TRANSMIT MESSAGE.
..PAGE
..HEAD02L ALDL NORMAL MESSAGE *$F0*
- MESSAGE ID = $F0
- MODE NUMBER = $F4
- CHECKSUM
..HEAD02L ALDL DATA LIST
..HEAD03L NUMBER OF DATA WORDS - 64
..HEAD04L ALDL MODE 1 DATA LIST
WORD DATA NAME DESCRIPTION
1 PROM ID FIRST PROM I.D. WORD (MSB)
2 PROM ID+1 SECOND PROM I.D. WORD (LSB)
PROM ID = (MSB * 256 + LSB)
3 COOLDEGA COOLANT TEMPERATURE
DEG. C = (N * 0.75) - 40
4 ADATSCSD MANIFOLD AIR TEMP. SENSOR
SEE LOOK-UP TABLE
5 ADTHROT THROTTLE POSITION SENSOR
VOLTS = N * 0.0199
6 NTPSLD THROTTLE ANGLE
% = N/2.56
7 NEWRFPER TIME BETWEEN REFERENCE PULSES (MSB)
8 NEWRFPER+1 TIME BETWEEN REFERENCE PULSES (LSB)
mSEC = (256MSB + LSB)/65.536
RPM = 1,310,720/(MSB*256 + LSB)
9 ISSPMP IDLE SPEED, PRESENT IAC MOTOR POSITION
COUNTS = POSITION
10 ISESDD DESIRED IDLE SPEED
RPM = N * 12.5
11 DISPFLOW MASS AIR FLOW (MSB)
12 DISPFLOW+1 MASS AIR FLOW (LSB)
GRAMS/SEC. = MSB + (LSB * .003906)
13 LV8 ENGINE LOAD VARIABLE
COUNTS = LOAD INDICATION
14 SAP TOTAL UNLIMITED SPARK (MSB)
15 SAP+1 TOTAL UNLIMITED SPARK ADVANCE (LSB)
double byte value in 2's complement representation
If Bit 7 of MSB = 0 then result is positive
value = (256MSB + LSB)
If Bit 7 of MSB = 1 then result is negative
value = 65536 - (256MSB + LSB)
DEGREES = VALUE * 90/256
16 OLDPA3 ELECTRONIC SPARK CONTROL (KNOCK) SIGNAL
YES/NO - YES IF ROLLOVER COUNTER CHANGED
- NO IF ROLLOVER COUNTER IS SAME VALUE
17 NOCKRTD ELECTRONIC SPARK CONTROL (KNOCK RETARD)
DEG = N * .176
18 AD02AF OXYGEN SENSOR VARIABLE
MILLIVOLTS = N * 4.44
19 ACNTDEL O2 CROSS COUNTS DELTA
NUMBER = O2 TOGGLES SINCE LAST SAMPLE
20 BLM BASE PULSE (FUEL) C.L. COURSE CORRECTION
N = (COUNTS)
21 CORRCL BASE PULSE (FUEL) C.L. FINE CORRECTION
N = (COUNTS)
22 BLMCELL BLMCELL - CURRENT BLOCK LEARN MULTIPLIER CELL
(NUMBER 0 - 16 POSSIBLE)
23 FAVAL TOTAL FUEL AIR VALUE (MSB)
24 FAVAL+1 TOTAL FUEL AIR VALUE (LSB)
A/F RATIO = 65536 / (40 * (MSB * 256 + LSB))
..PAGE
25 ACPRES A/C PRESSURE (NOT CURRENTLY USED)
V = 5N/255
PSI = (1.9063 * N)
26 ADBAT BATTERY VOLTAGE AD COUNTS
VOLTS = N / 10
27 PURGEDC CHARCOAL CANISTER PURGE DUTY CYCLE
% DC = N/2.56
28 M18CNTR CAM CRANK ERROR TIMER
N = (COUNTS)
29 BADCYL CURRENT WEAK CYLINDER DETECTED
(0 = NONE, 1 - 6 ACTUAL CYL. NO.)
NUMBER = CURRENT WEAK CYLINDER
30 S/C BOOST BOOST CONTROL DUTY CYCLE (L67 ONLY)
% DC = (N * 100) / 256
31 TIME ENGINE RUNNING TIME IN SECONDS (MSB)
32 TIME+1 ENGINE RUNNING TIME IN SECONDS (LSB)
SECONDS = (MSB * 256) + LSB
33 STATUS BITS (ALCLMW2):
7 CLOSED LOOP FLAG 1 = CLOSED LOOP
6 RICH/LEAN FLAG 1 = RICH
5 TRAILER TOWING MODE 1 = ON
4 GRADE CLIMBING MODE 1 = ON
3 ENGINE RUNNING 1 = RUNNING
2 CODE 42A PASSED (ALLOW CHECK OF M42B)
(1 = 42A PASSED, EST DIDN'T TOGGLE IN CRANK)
(0 = 42A FAILED, IN BYPASS W/ ENG. RUNNING)
1 HOT OPEN LOOP (FORCED OL DUE TO COOLANT TEMP)
(1 = IN HOT OPEN LOOP, 0 = NOT IN MODE)
0 VATS FUEL ENABLE (L67 ONLY) 1 = ENABLED
34 DISCRETE OUTPUT STATES (ALDLMW1):
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
3 EGR3 SOLENOID (LARGE) 1 = ON
2 EGR2 SOLENOID (MEDIUM) 1 = ON
1 EGR1 SOLENOID (SMALL) 1 = ON
0 DRIVER SELECT SW 1 = SPORTY, 0 = NORMAL
35 DISCRETE INPUT STATES (FMDBYTE1):
7 A/C REQUEST 1 = REQUESTED
6 TCC BRAKE 0 = PRESSED
5 CRUISE (ENABLE) BRAKE SW 0 = PRESSED
4 HIGH A/C PRES SW 1 = HIGH PRESSURE
3 A (PRNDL) (DECODER LINE)
2 B (PRNDL) (DECODER LINE)
1 C (PRNDL) (DECODER LINE)
0 P (PRNDL) (DECODER LINE)
..PAGE
36 DISCRETE INPUT STATES (FMDINST):
7 A/C REQUEST O = A/C REQUESTED
6 TCC BRAKE SWITCH (DEBOUNCED) 1 = PRESSED
5 C/C BRAKE SWITCH (DEBOUNCED)(IF EQUIPPED) 1 = ON
4 A/C HEAD PRESS. 1 = HIGH PRESSURE
3 4TH ACTUAL (GEAR) 0 = IN GEAR
2 3RD ACTUAL (GEAR) 0 = IN GEAR
1 2ND ACTUAL (GEAR) 0 = IN GEAR
0 P/N ACTUAL (PARK/NEUTRAL) 1 = IN P/N
37 STATUS BIT STATES (QDMMMW):
7 A/C CLUTCH (OUTPUT STATUS) 0 = ON
6 C/C VENT SOL (FEEDBACK)(IF EQUIPPED) 1 = ON
5 C/C VACUUM SOL (FEEDBACK)(IF EQUIPPED) 1 = ON
4 RESERVED FOR AIR SOLENOID (93 MY)
3 NOT USED
2 QDMB (2) (FAULT ACTIVE) 1 = NORMAL
1 QDMA (1) (FAULT ACTIVE) 1 = NORMAL
0 HEATED W/S REQ (IF EQUIPPED) 0 = REQUESTED
38 OUTPUT STATUS BIT STATES (LCCPMW):
7 CCP IDLE FLAG 1 = IDLE
6 NOT USED
5 ENGINE HOT LIGHT 1 = ON
4 FAN HI (COOLANT) 1 = ON
3 TORQUE CONV CL 1 = LOCKED
2 CLEAR MALF CODES 1 = YES
1 FAN LO (COOLANT) 1 = ON
0 CANISTER PURGE 1 = ON
39 RAWMPH - MPH KPH (VEHICLE SPEED)
MPH = N
40 PRNDL SWITCH:
(ONLY ONE BIT AT A TIME WILL BE SET, SET = 1)
7 PARK
6 REVERSE
5 NEUTRAL
4 DRIVE 4
3 DRIVE 3
2 DRIVE 2
1 LOW
0 INVALID
41 COMMANDED GEAR:
(CURRENT SHIFT SOLENOIDS COMMANDED GEAR) B2 B1 B0 GEAR
7 NOT USED --------------
6 NOT USED 0 0 0 NONE
5 NOT USED 0 0 1 FIRST
4 NOT USED 0 1 0 SECOND
3 NOT USED 0 1 1 THIRD
2 BINARY CODE 1 0 0 INVALID
1 BINARY CODE 1 0 1 INVALID
0 BINARY CODE 1 1 0 INVALID
1 1 1 FOURTH
..PAGE
42 FDSLIP - TORQUE CONVERTER SLIP (FILTERED):
RPM = 2(N-127)
43 TCCDC - TCC PWM SOLENOID DUTY CYCLE
DC = N/2.56
44 TCCPWMMW - TCC MODE:
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
3 OFF MODE 1 = OFF
2 RELEASE MODE (PWM) 1 = RELEASE
1 ON MODE 1 = ON
0 APPLY MODE (PWM) 1 = APPLY
45 CRUZW3 - CRUISE CONTROL INPUT SWITCHES (IF EQUIPPED):
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
3 C/C SET/CST SW 1 = ON
2 C/C RES/ACCEL SW 1 = ON
1 C/C ON/OFF SW 0 = ON
0 NOT USED
46 CRUISE MODE (CEUZMW2) (IF EQUIPPED):
(BIT THAT IS SET TO 1 DEFINES MODE)
7 NOT USED
6 COAST
5 ACCELERATE
4 RESUME
3 CRUISE
2 STANDBY
1 DISENGAGED
0 OFF
47 ADSERVO - CRUISE SERVO POSITION (IF EQUIPPED)
N = COUNTS
48 DSRVOPOS - DESIRED SERVO POSITION (IF EQUIPPED)
% = N/2.56
49 SERVOPOS - ACTUAL SERVO POSITION (IF EQUIPPED)
% = N/2.56
50 SETSPEED - CRUISE SET SPEED (IF EQUIPPED)
MPH = N
51 MALFFLG1 - HISTORY MALF FLAG WORD 1
7 HISTORY CODE 13 - O2 SENSOR
6 HISTORY CODE 14 - COOLANT SENSOR HIGH
5 HISTORY CODE 15 - COOLANT SENSOR LOW
4 HISTORY CODE 16 - BATTERY VOLTAGE HIGH/LOW
3 HISTORY CODE 17 - RPM SIGNAL PROBLEM
2 HISTORY CODE 18 - CAM/CRANK ERROR
1 HISTORY CODE 19 - NOT USED
0 HISTORY CODE 21 - THROTTLE POSITION HIGH
..PAGE
52 MALFFLG2 - HISTORY MALF FLAG WORD 2
7 HISTORY CODE 22 - THROTTLE POSITION LOW
6 HISTORY CODE 23 - AIR SENSOR TEMP LOW
5 HISTORY CODE 24 - VSS LOW
(OR W/ BYTE 56 BIT 1 FOR DISPLAY)
4 HISTORY CODE 25 - AIR TEMP SENSOR HIGH
3 HISTORY CODE 26 - QDM "A" FAULT
2 HISTORY CODE 27 - 2ND GEAR SWITCH FAILURE (440 ONLY)
1 HISTORY CODE 28 - 3RD GEAR SWITCH FAILURE (440 ONLY)
0 HISTORY CODE 29 - 4TH GEAR SWITCH FAILURE (440 ONLY)
53 MALFFLG3 - HISTORY MALF FLAG WORD 3
7 HISTORY CODE 31 - P/N SWITCH FAILURE (440)
6 HISTORY CODE 31 - PRNDL SWITCHES FAULT (F31)
5 HISTORY CODE 33 - NOT USED
4 HISTORY CODE 34 - MASS AIR FLOW SENSOR FAILURE
3 HISTORY CODE 35 - NOT USED
2 HISTORY CODE 36 - TRANS SHIFT PROBLEM (F31)
1 HISTORY CODE 24 - VSS LOW
(OR W/ BYTE 55 BIT 5 FOR DISPLAY)
0 HISTORY CODE 38 - TCC BRAKE SWITCH FAILURE
54 MALFFLG4 - HISTORY MALF FLAG WORD 4
7 HISTORY CODE 39 - TCC FAILURE
6 HISTORY CODE 41 - CAM SENSOR FAILURE
5 HISTORY CODE 42 - EST FAILURE
4 HISTORY CODE 43 - ESC FAILURE
3 HISTORY CODE 44 - O2 SENSOR LEAN
2 HISTORY CODE 45 - O2 SENSOR RICH
1 HISTORY CODE 46 - POWER STEERING PRESSURE SW (NOT USED)
0 HISTORY CODE 47 - UART LINK FAILURE (GM30/33 ONLY)
55 MALFFLG5 - HISTORY MALF FLAG WORD 5
7 HISTORY CODE 48 - NOT USED
6 HISTORY CODE 49 - NOT USED
5 HISTORY CODE 51 - PROM ERROR
4 HISTORY CODE 52 - NOT USED
3 HISTORY CODE 53 - EGR 1 (SMALL) SOLENOID FAILURE
2 HISTORY CODE 54 - EGR 2 (MEDIUM) SOLENOID FAILURE
1 HISTORY CODE 55 - EGR 3 (LARGE) SOLENOID FAILURE
0 HISTORY CODE 56 - QDM "B" FAULT
56 MALFFLG6 - HISTORY MALF FLAG WORD 6
7 HISTORY CODE 57 - BOOST CONTROL FAILURE (IF EQUIPPED)
6 HISTORY CODE 58 - VATS FAILURE (IF EQUIPPED)
5 HISTORY CODE 66 - A/C FREON LOW
4 HISTORY CODE 61 - CRUISE VENT SOL FAILURE (IF EQUIPPED)
3 HISTORY CODE 62 - CRUISE VACUUM SOL FAILURE (IF EQUIPPED)
2 HISTORY CODE 63 - CC position sensor voltage low
1 HISTORY CODE XX - NOT USED
0 HISTORY CODE XX - NOT USED
..PAGE
57 MALFFLG7 - HISTORY MALF FLAG WORD 7
7 HISTORY CODE 88 - PCM RESET (MASKED FOR PRODUCTION)
6 HISTORY CODE 66 - A/C PRESSURE TRANSDUCER (NOT USED)
5 HISTORY CODE 67 - CRUISE SWITCHES FAULT (IF EQUIPPED)
4 HISTORY CODE 68 - CC position sensor voltage high
3 HISTORY CODE 65 - CRUISE SERVO POS SENSOR (IF EQUIPPED)
2 HISTORY CODE 69 - HIGH A/C PRESS. SW. FAULT
1 HISTORY CODE 99 - POWER MANAGEMENT (ACTIVATED/ENABLED)
58 CURMALF1 - CURRENT MALF FLAG WORD 1
7 CURRENT CODE 13 - O2 SENSOR
6 CURRENT CODE 14 - COOLANT SENSOR HIGH
5 CURRENT CODE 15 - COOLANT SENSOR LOW
4 CURRENT CODE 16 - BATTERY VOLTAGE HIGH/LOW
3 CURRENT CODE 17 - RPM SIGNAL PROBLEM
2 CURRENT CODE 18 - CAM/CRANK ERROR
1 CURRENT CODE 19 - NOT USED
0 CURRENT CODE 21 - THROTTLE POSITION HIGH
59 CURMALF2 - CURRENT MALF FLAG WORD 2
7 CURRENT CODE 22 - THROTTLE POSITION LOW
6 CURRENT CODE 23 - AIR SENSOR TEMP LOW
5 CURRENT CODE 24 - VSS LOW
(OR W/ BYTE 63 BIT 1 FOR DISPLAY)
4 CURRENT CODE 25 - AIR TEMP SENSOR HIGH
3 CURRENT CODE 26 - QDM "A" FAULT
2 CURRENT CODE 27 - 2ND GEAR SWITCH FAILURE (440 ONLY)
1 CURRENT CODE 28 - 3RD GEAR SWITCH FAILURE (440 ONLY)
0 CURRENT CODE 29 - 4TH GEAR SWITCH FAILURE (440 ONLY)
60 CURMALF3 - CURRENT MALF FLAG WORD 3
7 CURRENT CODE 31 - P/N SWITCH FAILURE (440)
6 CURRENT CODE 31 - PRNDL SWITCHES FAULT (F31)
5 CURRENT CODE 33 - NOT USED
4 CURRENT CODE 34 - MASS AIR FLOW SENSOR FAILURE
3 CURRENT CODE 35 - NOT USED
2 CURRENT CODE 36 - TRANS SHIFT PROBLEM (F31)
1 CURRENT CODE 24 - VSS LOW
(OR W/ BYTE 62 BIT 5 FOR DISPLAY)
0 CURRENT CODE 38 - TCC BRAKE SWITCH FAILURE
61 CURMALF4 - CURRENT MALF FLAG WORD 4
7 CURRENT CODE 39 - TCC FAILURE
6 CURRENT CODE 41 - CAM SENSOR FAILURE
5 CURRENT CODE 42 - EST FAILURE
4 CURRENT CODE 43 - ESC FAILURE
3 CURRENT CODE 44 - O2 SENSOR LEAN
2 CURRENT CODE 45 - O2 SENSOR RICH
1 CURRENT CODE 46 - POWER STEERING PRESSURE SW (NOT USED)
0 CURRENT CODE 47 - UART LINK FAILURE (GM30/33) (NOT USED)
..PAGE
62 CURMALF5 - CURRENT MALF FLAG WORD 5
7 CURRENT CODE 48 - NOT USED
6 CURRENT CODE 49 - NOT USED
5 CURRENT CODE 51 - PROM ERROR
4 CURRENT CODE 52 - NOT USED
3 CURRENT CODE 53 - EGR 1 (SMALL) SOLENOID FAILURE
2 CURRENT CODE 54 - EGR 2 (MEDIUM) SOLENOID FAILURE
1 CURRENT CODE 55 - EGR 3 (LARGE) SOLENOID FAILURE
0 CURRENT CODE 56 - QDM "B" FAULT
63 CURMALF6 - CURRENT MALF FLAG WORD 6
7 CURRENT CODE 57 - BOOST CONTROL FAILURE (IF EQUIPPED)
6 CURRENT CODE 58 - VATS FAILURE (IF EQUIPPED)
5 CURRENT CODE 66 - A/C FREON LOW
4 CURRENT CODE 61 - CRUISE VENT SOL FAILURE (IF EQUIPPED)
3 CURRENT CODE 62 - CRUISE VACUUM SOL FAILURE (IF EQUIPPED)
2 CURRENT CODE 63 - CC position sensor voltage low
1 CURRENT CODE XX - NOT USED
0 CURRENT CODE XX - NOT USED
64 CURMALF7 - CURRENT MALF FLAG WORD 7
7 CURRENT CODE 88 - PCM RESET (MASKED FOR PRODUCTION)
6 CURRENT CODE 66 - A/C PRESSURE TRANSDUCER (NOT USED)
5 CURRENT CODE 67 - CRUISE SWITCHES FAULT (IF EQUIPPED)
4 CURRENT CODE 68 - CC position sensor voltage high
3 CURRENT CODE 65 - CRUISE SERVO POS SENSOR (IF EQUIPPED)
2 CURRENT CODE 69 - HIGH A/C PRESS. SW. FAULT
1 CURRENT CODE 99 - POWER MANAGEMENT (ACTIVATED/ENABLED)
;ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
;³ ³
;³ MANIFOLD AIR TEMP ³
;³ (LOOK-UP TABLE) ³
;³ ³
;ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
A/D DEG C DEG F
0 -40 -40
1 -39 -37.3
2 -38 -36.5
3 -37 -34.7
4 -36.1 -32
5 -35.1 -30.2
6 -34.1 -29.4
7 -33.1 -27.6
8 -32.1 -24.9
9 -31.1 -24.1
10 -30.2 -22.3
11 -29.2 -19.6
12 -28.2 -17.8
13 -27.2 -17
14 -26.2 -15.2
15 -25.2 -12.5
16 -24.2 -10.7
17 -23.5 -9.3
18 -22.7 -8.8
19 -21.9 -6.4
20 -21.1 -5
21 -20.3 -4.5
22 -19.5 -2.1
23 -18.7 -.7000001
24 -17.9 -.2
25 -17.1 2.2
26 -16.3 3.6
27 -15.5 4.1
28 -14.7 6.5
29 -13.9 7.9
30 -13.1 8.399999
31 -12.3 10.8
32 -11.5 12.2
33 -10.9 12.3
34 -10.4 13.3
35 -9.8 14.3
36 -9.2 16.3
37 -8.7 17.3
38 -8.100001 18.3
39 -7.6 19.3
40 -7 19.4
41 -6.4 20.4
42 -5.9 21.4
43 -5.3 22.4
44 -4.7 24.4
45 -4.2 25.4
46 -3.6 26.4
47 -3.1 27.4
48 -2.5 27.5
49 -2.1 29.2
50 -1.7 29
51 -1.2 30.7
52 -.8 30.5
53 -.4 32.2
54 0 33
55 .5 32.8
56 .9 34.5
57 1.3 34.3
58 1.7 36
59 2.1 36.8
60 2.6 36.6
61 3 38.3
62 3.4 38.1
63 3.8 39.8
64 4.3 40.6
65 4.7 40.4
66 5.1 42.1
67 5.5 41.9
68 5.9 43.6
69 6.4 43.4
70 6.8 44.2
71 7.2 45.9
72 7.6 45.7
73 8 47.4
74 8.5 47.2
75 8.899999 48
76 9.3 49.7
77 9.7 49.5
78 10.2 51.2
79 10.6 51
80 11 51.8
81 11.3 53.3
82 11.7 53.9
83 12 54.5
84 12.3 55.1
85 12.6 55.7
86 13 55.3
87 13.3 55.9
88 13.6 56.5
89 14 57.1
90 14.3 57.7
91 14.6 59.2
92 14.9 59.8
93 15.3 60.4
94 15.6 61
95 15.9 61.6
96 16.3 62.2
97 16.6 61.9
98 17 62.6
99 17.4 64.2
100 17.8 64.9
101 18.1 64.6
102 18.5 65.3
103 18.9 66.9
104 19.3 67.6
105 19.6 67.3
106 20 68
107 20.4 69.6
108 20.8 70.3
109 21.1 70
110 21.5 70.7
111 21.9 72.3
112 22.3 73
113 22.6 72.6
114 22.9 73.2
115 23.2 73.8
116 23.6 74.4
117 23.9 75
118 24.2 76.5
119 24.5 77.1
120 24.9 77.7
121 25.2 78.3
122 25.5 78.9
123 25.9 78.5
124 26.2 79.1
125 26.5 79.7
126 26.8 80.3
127 27.2 80.9
128 27.5 81.5
129 27.9 83.1
130 28.3 83.8
131 28.6 83.5
132 29 84.2
133 29.4 85.8
134 29.8 86.5
135 30.1 86.2
136 30.5 86.9
137 30.9 88.5
138 31.3 89.2
139 31.6 88.9
140 32 89.6
141 32.4 91.2
142 32.8 91.9
143 33.1 91.6
144 33.5 92.3
145 33.9 93.9
146 34.3 93.6
147 34.6 94.3
148 35 95
149 35.4 96.6
150 35.8 97.3
151 36.1 97
152 36.5 97.7
153 36.9 99.3
154 37.3 100
155 37.6 99.7
156 38 101.3
157 38.4 102
158 38.8 102.7
159 39.1 102.4
160 39.5 103.1
161 39.9 104.8
162 40.3 104.6
163 40.8 106.3
164 41.2 106.1
165 41.6 107.8
166 42 108.6
167 42.5 108.4
168 42.9 110.1
169 43.3 109.9
170 43.7 111.6
171 44.1 112.4
172 44.6 112.2
173 45 113.9
174 45.4 113.7
175 45.8 115.4
176 46.3 116.2
177 46.8 117.1
178 47.3 117.1
179 47.8 118
180 48.3 119.9
181 48.8 120.8
182 49.3 120.8
183 49.9 121.7
184 50.4 123.6
185 50.9 123.6
186 51.4 124.5
187 51.9 126.4
188 52.4 127.3
189 53 127.3
190 53.5 128.2
191 54 130.1
192 54.5 130.1
193 55.1 132.1
194 55.7 133.2
195 56.3 134.3
196 56.9 135.4
197 57.5 136.5
198 58.2 137.6
199 58.8 138.7
200 59.4 139.8
201 60 140.9
202 60.6 142
203 61.2 143.1
204 61.8 144.2
205 62.4 145.3
206 63 146.4
207 63.6 147.5
208 64.3 148.6
209 65.1 150.1
210 65.9 151.6
211 66.8 152.2
212 67.6 153.7
213 68.5 155.2
214 69.3 157.7
215 70.2 159.2
216 71 159.8
217 71.8 161.3
218 72.7 162.8
219 73.5 165.3
220 74.4 166.8
221 75.2 168.3
222 76.1 168.9
223 76.9 170.4
224 77.8 172.9
225 79.3 174.7
226 80.8 177.5
227 82.4 180.3
228 83.9 184
229 85.5 186.8
230 87 189.6
231 88.6 191.4
232 90.1 194.2
233 91.7 197
234 93.2 200.7
235 94.8 203.5
236 96.3 206.3
237 97.9 208.1
238 99.4 210.9
239 101 213.7
240 102.5 216.5
241 105.5 222.9
242 108.6 228.4
243 111.6 233.9
244 114.7 238.4
245 117.7 243.9
246 120.8 249.4
247 123.8 255.8
248 126.9 261.3
249 129.9 266.8
250 133 271.3
251 136 276.8
252 139.1 282.3
253 142.1 288.7
254 145.2 294.2
255 148.2 299.7
ENGINE USAGE:
BAUD RATE: 8192
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $00
- MESSAGE CHECKSUM
ECM RESPONSE:
NORMAL MESSAGES
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $01
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $01
- DATA BYTE 1
- DATA BYTE 64
- CHECKSUM
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $07
- CHECKSUM
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $08
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $08
- CHECKSUM
..PAGE
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $09
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $09
- CHECKSUM
ALDL REQUEST:
- MESSAGE ID = $F4
- MODE NUMBER = $0A
- CHECKSUM
- MESSAGE ID = $F4
- MODE NUMBER = $0A
- CHECKSUM
..PAGE
..PAGE
- MESSAGE ID = $F0
- MODE NUMBER = $F4
- CHECKSUM
SEE LOOK-UP TABLE
VOLTS = N * 0.0199
% = N/2.56
COUNTS = POSITION
RPM = N * 12.5
DEG = N * .176
N = (COUNTS)
N = (COUNTS)
..PAGE
V = 5N/255
PSI = (1.9063 * N)
VOLTS = N / 10
% DC = N/2.56
N = (COUNTS)
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
..PAGE
3 NOT USED
6 NOT USED
MPH = N
40 PRNDL SWITCH:
7 PARK
6 REVERSE
5 NEUTRAL
4 DRIVE 4
3 DRIVE 3
2 DRIVE 2
1 LOW
0 INVALID
41 COMMANDED GEAR:
1 1 1 FOURTH
..PAGE
RPM = 2(N-127)
DC = N/2.56
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
3 OFF MODE 1 = OFF
1 ON MODE 1 = ON
7 NOT USED
6 NOT USED
5 NOT USED
4 NOT USED
0 NOT USED
7 NOT USED
6 COAST
5 ACCELERATE
4 RESUME
3 CRUISE
2 STANDBY
1 DISENGAGED
0 OFF
N = COUNTS
% = N/2.56
% = N/2.56
MPH = N
..PAGE
..PAGE
..PAGE
;³ ³
;³ ³
A/D DEG C DEG F
0 -40 -40
1 -39 -37.3
2 -38 -36.5
3 -37 -34.7
4 -36.1 -32
5 -35.1 -30.2
6 -34.1 -29.4
7 -33.1 -27.6
8 -32.1 -24.9
9 -31.1 -24.1
10 -30.2 -22.3
11 -29.2 -19.6
12 -28.2 -17.8
13 -27.2 -17
14 -26.2 -15.2
15 -25.2 -12.5
16 -24.2 -10.7
17 -23.5 -9.3
18 -22.7 -8.8
19 -21.9 -6.4
20 -21.1 -5
21 -20.3 -4.5
22 -19.5 -2.1
23 -18.7 -.7000001
24 -17.9 -.2
25 -17.1 2.2
26 -16.3 3.6
27 -15.5 4.1
28 -14.7 6.5
29 -13.9 7.9
30 -13.1 8.399999
31 -12.3 10.8
32 -11.5 12.2
33 -10.9 12.3
34 -10.4 13.3
35 -9.8 14.3
36 -9.2 16.3
37 -8.7 17.3
38 -8.100001 18.3
39 -7.6 19.3
40 -7 19.4
41 -6.4 20.4
42 -5.9 21.4
43 -5.3 22.4
44 -4.7 24.4
45 -4.2 25.4
46 -3.6 26.4
47 -3.1 27.4
48 -2.5 27.5
49 -2.1 29.2
50 -1.7 29
51 -1.2 30.7
52 -.8 30.5
53 -.4 32.2
54 0 33
55 .5 32.8
56 .9 34.5
57 1.3 34.3
58 1.7 36
59 2.1 36.8
60 2.6 36.6
61 3 38.3
62 3.4 38.1
63 3.8 39.8
64 4.3 40.6
65 4.7 40.4
66 5.1 42.1
67 5.5 41.9
68 5.9 43.6
69 6.4 43.4
70 6.8 44.2
71 7.2 45.9
72 7.6 45.7
73 8 47.4
74 8.5 47.2
75 8.899999 48
76 9.3 49.7
77 9.7 49.5
78 10.2 51.2
79 10.6 51
80 11 51.8
81 11.3 53.3
82 11.7 53.9
83 12 54.5
84 12.3 55.1
85 12.6 55.7
86 13 55.3
87 13.3 55.9
88 13.6 56.5
89 14 57.1
90 14.3 57.7
91 14.6 59.2
92 14.9 59.8
93 15.3 60.4
94 15.6 61
95 15.9 61.6
96 16.3 62.2
97 16.6 61.9
98 17 62.6
99 17.4 64.2
100 17.8 64.9
101 18.1 64.6
102 18.5 65.3
103 18.9 66.9
104 19.3 67.6
105 19.6 67.3
106 20 68
107 20.4 69.6
108 20.8 70.3
109 21.1 70
110 21.5 70.7
111 21.9 72.3
112 22.3 73
113 22.6 72.6
114 22.9 73.2
115 23.2 73.8
116 23.6 74.4
117 23.9 75
118 24.2 76.5
119 24.5 77.1
120 24.9 77.7
121 25.2 78.3
122 25.5 78.9
123 25.9 78.5
124 26.2 79.1
125 26.5 79.7
126 26.8 80.3
127 27.2 80.9
128 27.5 81.5
129 27.9 83.1
130 28.3 83.8
131 28.6 83.5
132 29 84.2
133 29.4 85.8
134 29.8 86.5
135 30.1 86.2
136 30.5 86.9
137 30.9 88.5
138 31.3 89.2
139 31.6 88.9
140 32 89.6
141 32.4 91.2
142 32.8 91.9
143 33.1 91.6
144 33.5 92.3
145 33.9 93.9
146 34.3 93.6
147 34.6 94.3
148 35 95
149 35.4 96.6
150 35.8 97.3
151 36.1 97
152 36.5 97.7
153 36.9 99.3
154 37.3 100
155 37.6 99.7
156 38 101.3
157 38.4 102
158 38.8 102.7
159 39.1 102.4
160 39.5 103.1
161 39.9 104.8
162 40.3 104.6
163 40.8 106.3
164 41.2 106.1
165 41.6 107.8
166 42 108.6
167 42.5 108.4
168 42.9 110.1
169 43.3 109.9
170 43.7 111.6
171 44.1 112.4
172 44.6 112.2
173 45 113.9
174 45.4 113.7
175 45.8 115.4
176 46.3 116.2
177 46.8 117.1
178 47.3 117.1
179 47.8 118
180 48.3 119.9
181 48.8 120.8
182 49.3 120.8
183 49.9 121.7
184 50.4 123.6
185 50.9 123.6
186 51.4 124.5
187 51.9 126.4
188 52.4 127.3
189 53 127.3
190 53.5 128.2
191 54 130.1
192 54.5 130.1
193 55.1 132.1
194 55.7 133.2
195 56.3 134.3
196 56.9 135.4
197 57.5 136.5
198 58.2 137.6
199 58.8 138.7
200 59.4 139.8
201 60 140.9
202 60.6 142
203 61.2 143.1
204 61.8 144.2
205 62.4 145.3
206 63 146.4
207 63.6 147.5
208 64.3 148.6
209 65.1 150.1
210 65.9 151.6
211 66.8 152.2
212 67.6 153.7
213 68.5 155.2
214 69.3 157.7
215 70.2 159.2
216 71 159.8
217 71.8 161.3
218 72.7 162.8
219 73.5 165.3
220 74.4 166.8
221 75.2 168.3
222 76.1 168.9
223 76.9 170.4
224 77.8 172.9
225 79.3 174.7
226 80.8 177.5
227 82.4 180.3
228 83.9 184
229 85.5 186.8
230 87 189.6
231 88.6 191.4
232 90.1 194.2
233 91.7 197
234 93.2 200.7
235 94.8 203.5
236 96.3 206.3
237 97.9 208.1
238 99.4 210.9
239 101 213.7
240 102.5 216.5
241 105.5 222.9
242 108.6 228.4
243 111.6 233.9
244 114.7 238.4
245 117.7 243.9
246 120.8 249.4
247 123.8 255.8
248 126.9 261.3
249 129.9 266.8
250 133 271.3
251 136 276.8
252 139.1 282.3
253 142.1 288.7
254 145.2 294.2
255 148.2 299.7
rangers458
How about an ADS for a 95 Camaro LT1?
I found $EE file, but there is no ADS for that. I was looking at the A274 ALDL data, and trying to figure out how to make it myself, but since I am very new to this program, I am not sure what bits, and bytes they are referring to in the message stream.
That would be great!
maybe if you kiss mark's ass enough, you can get it earlyrangers458 wrote:And where do I get Version 5?
http://tunerpro.net/forum/viewtopic.php?t=1404
LOTS of people are waiting, trust me...
I need an ADS for $31, also does anyone have a bigger xdf than the one on moates?
Dan- ASE certified-A1, A4, A5, A8
95 S10 ecsb, 350, 9.5:1, ported Vortec heads, Crane(.484/.512 272/284 112LSA), OBD2 L31 intake, Hooker LT's, 2.5"ORY, Flowmaster 40, 4L60E, 8.8 posi w/ 3.73's, WBO2, '7427 PCM running in PFI mode, $OD.
by $31 are you refering to a turbo 3.8 motor or a NA motor?
for a T31 (1227148) XDF, download the one on the TP downloads page. it took me about 12 hours for that one.
for a NA(1227153) i have a XDF for it thats 76KB in size.
i didn't make the T31 XDF on the downloads page, but if you feel its lacking let me know, and i'll make a full one.
i don't know if a NA 31 ADS exists, but if its what you have, then let me know and i'll whip one up.
This is a 16197427 in a 95 k2500, 350, tbi, 4L80E. I have read that its either $31 or $0E and with 0E a few of the values are crazy so I figured it was 31. unfortunately its not $0D.
The bin I read from my memcal, the case said BNKM and I dont have any reason to think its not it.
I cant tell anymore if I think its $31 or $0E and neither of the xdf's I have display Mask ID like my $0D one does.
Just to see I opened $0D back op, selected the bin I read from my memcal as the compare to bin and opened mask ID and it is 31, I dont know if you can trust doing it that way though.
I got a ninja edit in on you.
I dont think its $0D, all 3 (0D,0E, and 31) are so close that cant really tell, I am getting the same thing as you with the spark table being normal looking and the VE being crazy in 0D and 0E, only in $31 does everything look normal. That plus the mask ID being 31 has me almost convinced this thing is $31.
Okay after some more checking it is without a doubt $31, the fuel cut-out from my chip read is 0rpm in 0D, 2000rpm in 0E and 4800 in $31. Brings me back to the original topic at hand, do you think I could pretty please get a ads for this $31?
Thank you sirrobertisaar wrote:$31
16197427 or 16156930
95 C/K Truck, Van
5.7L & 7.4L (HD)
95 - 96 Hummer H1 (Gas)
i'll look through my files in the morning.
Hi Robert, Mark M. referred me here to ask about fixing/creating an ADS for my vehicle. Thanks for this service you provide!
I have a 1990 Cadillac Sedan deVille (4.5L TPI V8), PCM #16132240 ($CD1, ATTL mask). I found an .ADS for the '91-'93 PCM of my car (same serv. #) in the user contributed section on the TP website, but so far it hasn't worked.
My main issue is that when I turn on the ignition, TPRTv4 no longer recognizes my ALDL cable being connected. If I leave off the ignition and do a check in TP, it detects the cable. As soon as I turn on the ignition or start the engine, it's like it can't see it any more. This happens in both standard cable mode. In APU1 mode, there is no response from PCM when attempting to connect.
Mark says this could be from talking on the ALDL line for which the ADS file doesn't have provisions.
What do you think? Can you help me with an .ads file for my PCM/vehicle?
Solomon
Solomon
X-Machines
