A9L bin file
NickHemmesch
A9L bin file
Post by NickHemmesch »
Hi,
TunerPro RT seems to want a 64k A9L bin file to read it properly.
Where can I find the proper bin, or how can I load a 56K bin?
Thanks in advance . . .
Nick Hemmesch
nick@qmailtoaster.com
Two solutions to this :D either
Use a hex editor to 'pad out' the first 8192 bytes with null data.
or
Edit the xdf header (cntl + F2) and change the bin size to 'E000', put a base offset of '2000' in and check the 'subtract' tick box.
NickHemmesch
Hi Dex,
Thanks for the info. I will give it a try.
Regards,
Nick Hemmesch
NickHemmesch
Hi Dex,
That worked fine. Thanks . . .
Nick Hemmesch
David Claflin
Post by David Claflin »
dex wrote:Edit the xdf header (cntl + F2) and change the bin size to 'E000', put a base offset of '2000' in and check the 'subtract' tick box.
I tried this method and it didn't work for me. I lost all of the functions/scalars. I'll have to download an editor and see if I can make that work.
Edit> I'm officially a retard. :oops: I tried the header edit before I loaded the bin. I tried afterwards and it seems to be OK. Thanks!!!
No worries, we all make mistakes when learning something new :D
