M3.3.1 motronic (413 and 506) tuning and XDF update?
Hairyscreech
To back you up on that the E30 thermostat is 80 to 88 degrees and that is central/vertical on my gauge, I hit that last cell while still at the 1/4 mark on the gauge, so likely about 50-60 degrees.
I have been plugging it into a few tables today to see how if fits, looks ok but might be worth testing this out on a few other tables.
It seems to work for the D4 IAT as well but I could only find one table with D4 on.
If you wanted to test it put a resistor with a value matching one of the temperatures in place of the CLT and check what cell that puts the ECU into. I believe that table is always active even at idle so it should be easy to check.
It would imply that there is no CLT or IAT transfer function though, with no requirement to work across several different kinds of hardware and no need to spit out OBD2 PIDs there is no need for the temperature to be anything but an abstraction in the code.
A simple more=more value in the code with the only direct relation to temperature being the voltage to the A2D converter, more temperature=more voltage=higher value with no direct conversion factor.
10bit A/D converter can be used in 8bit by using only 8 most significant bits.Hairyscreech wrote:I believe this is simply the raw 256 bit values from the A2D converter. I get that the A2D is 10bit and would then have to convert into 8bit somewhere in the code, that would simply be the 0-1023 converted to 0-255.
The A2D works from 0-5v, with 255 values available that's 0.019531V/value.
The sensor is not liner but using the calculations I put on the "M5x temp sensors" sheet in the dropbox and working out the voltages expected at the A2D based on the voltage divider layout and using this V/value I built a table of temperature Vs D7 value.
I found that the a 0v value would be ~-40 DegC and a 5v value ~215 DegC.
While the sensor would never actually measure a full 0v or 5v due to the way it works and should never see these kind of temperatures is gave me the boundaries.
I have updated the sheet in the dropbox to show this working so if anyone wants to double check it then feel free, the more eyes checking these things the better.
Plugging the resulting numbers into the D7 based tables gives some sensible results:
The "coolant temp correction for acceleration" table has the following:
Raw value - 49 103 143 175
Temp DegC - 0 30 50 66
Running the car from cold results in a steady climb up that table and it sits in the 66+ cell once 3/4 warm. (E30 temp gauge so not electrically damped like an E36).
I am going to put the values into some of the unknown D7 tables and see what temperatures it suggests, it will help confirm if the theory is correct and maybe what those tables are.
Example: register addresses 46 and 47 seems to be MAF values. So, they are 16bit, but i didn't note which is 8 most significant. But, if other one is overflowed, it increses by one that other one, and that overflowed will start from zero. If you read only that "increase one by overflow" you get 8bit maf value.
Hairyscreech
Its interesting you post that as it looks like some of the code does that to get offsets, there are a couple of times something is added to an Exxxh or Fxxxh number and put into an 8 bit register, this obviously can only drop the extra values off the end of the register.
Seems like it is a dirty trick to prevent having to subtract numbers. (which I think is more processor intensive?)
I'm not sure the A2D converter is used like that though as the values in the tables suggest a full range scaled down to 8bit with 255 meaning 5v (about 215 DegC).
Unless I am understanding the math/mechanics of the thing?
Are you suggesting it could be 0-1020 by only using the first 8bits of the 10bit value?
Essentially dropping the first 2 bits and making the value off by 3?
Edit - I think I just got it, in the first example it would be dropping the most significant bit/bits and essentially "going around the clock" to get back from high hex values to low hex values but the A2D example is a little different:
If the value is 10 bits then 1/2 = 512 = 10 0000 0000.
Dropping the first 2 bits gives 10 0000 00| (00 dropped) and thus 8bit 128 value.
The way binary works you wont fill up the most significant bits until the highest values for a given number of bits, so discarding the least significant automatically converts to a different size without changing the numbers % value.
70% of 10 bits becomes 70% of 8 bits by just dropping the first 2 bits.
I just had a play and it actually converts 10bit numbers to 8bit very well, it is an elegant solution that saves a lot of math in the processor.
(I did say my computer science was lacking -
I gather this will mean if I have a quick hunt for some 10 to 16 bit values and take a look to see if some are being addressed in a funny way or are being deliberately bit shifted then we might find the A2D code?
Direct copy from 80196 user's manual A/D section:
"11.0 A/D CONVERTER
Analog Inputs to the 80C196KB System are handled
by the A/D converter System. As shown in Figure
11-4, the converter system has an 8 channel multiplexer,
a sample-and-hold, and a 10 bit successive approximation
A/D converter. Conversions can be performed
on one of eight channels, the inputs of which share pins
with port 0. A conversion can be done in as little as 91
state times.
Conversions are started by loading the AD_COMMAND
register at location 02H with the channel number.
The conversion can be started immediately by setting
the GO bit to a one. If it is cleared the conversion
will start when the HSO unit triggers it. The A/D command
register must be written to for each conversion,
even if the HSO is used as the trigger. The result of
the conversion is read in the ADÃRESULT(High)
and AD_RESULT(Low) registers. The AD_RESULT(
High) contains the most significant eight bits of
the conversion. The AD_RESULT(Low) register contains
the remaining two bits and the A/D channel number
and A/D status. The format for the AD_COMMAND
register is shown in Figure 11-1. In Window
15, reading the AD_COMMAND register will read
the last command written. Writing to the AD_RESULT
register will write a value into the result register."
02H:
BIT FUNCTION
0 Channel selection (+1)
1 Channel selection (+2)
2 Channel selection (+4)
3 GO-bit (when written to "1" conversion will start asap)
4 X
5 X
6 Least significant result bit
7 Second least significant result bit
By reading 02H is used to check ADC status and last used channel. Bit 3 will clear to "0" automatically, when conversion is finished, so, when reading 02H and bit 3 is "1" it means AD conversion is running, converter is busy.
"11.0 A/D CONVERTER
state times.
02H:
BIT FUNCTION
4 X
5 X
Hairyscreech
Well noted.
I have used that to edit the disassembly I have and it highlights the times when the program uses the A2D quite well.
Just by spotting the A2D write on 02H and then read on 03H then 02H you can find all 5 reads of the A2D in the 413 ROM.
Lets see if anything useful can come of that.
Edit - Further note, anywhere the program has a JBS (jump if bit set) for the AD command register 02H then it is waiting for the A2D read to finish.
That's done to put the program into a brief loop to give the ~42 micro seconds for the A2D to finish.
This is all becoming a little bit too much like learning things...
Hairyscreech
MyKK - I spotted a post by you here: https://www.bimmerforums.com/forum/show ... 4DME-M60-s
Regarding those TPS limits tables, how did you find those and know what the RPM thresholds were/are?
When I was looking at the transfer function area those 12 bytes where they are located was the only thing I could not work out.
On my last tuning run in the E30 I couldn't get the WOT tables to activate, this might help resolve that as I think the issue is a tiny difference in the angular range on the E30 throttle.
For the TPS thresolds, the RPM values are those in the XDF shared by Olafu about this, sooner in this thread.
I have never checked if it was correct for my 403, but the thresolds are working for sure, I modified them for my ITBs because TPS range was very shorter on them..
I think that the different thresolds by RPM are to avoid Idle/PT switching when cruising. I put the same value in all cells with no problem but maybe due to my particular setup...
I never found RPM axis data for idle/pt/wot tables, i think it is shared for multiple tables and it is somewhere close of those threshold tables. RPM's for those thresholds in my XDF was purely found by testing and tracing. They are not very accurate.
I did take a break in playing with this device, because HEX's started to flow out from my ears.
Hairyscreech
I know that feeling. I have been taking a step back and working on other projects a little as well, my key focus has been to get the E30 working right so less finding new stuff and more making what we have work right.olafu wrote:I never found RPM axis data for idle/pt/wot tables, i think it is shared for multiple tables and it is somewhere close of those threshold tables. RPM's for those thresholds in my XDF was purely found by testing and tracing. They are not very accurate.
Also been putting together some coil overs for it and trying to get a friends Drift Cup car ready for this season.
All been keeping me busy.
I want to try and work out which sensors are on each of the A/D inputs as the next step, that will ID several functions in the Code as the reading of those sensors. I started trying to trace to boards back using the Hi-res photos I took but I think I need another board out of the car to check and ebay is only bringing them up @£150+
Revlimit - At the moment, not really. I have a few but not hosted them anywhere since photobucket killed the internet (a decision I expect they may regret long term).
I will look at getting some sorted out, it is not too pretty as a better engine will be built and things tidied up a bit when that happens but its all in there and everything functioning.
General question for all - I have found over the last few weeks I am not getting tuner pro to trace the WOT fuel maps, the ECU is 100% hitting WOT, verified by the step change in the fuelling if I change those maps and INPA but I cant get those maps to trace.
Any ideas what could be causing the issue? Short of an issue with the older laptop and TunerPro I cannot think why they wont trace. Everything else seems to be working/tracing fine bar those WOT fuel maps.
Going to try using my newer laptop again and see if its that, otherwise I guess the arduino logger will make the hit tracing a little redundant.
Edit - I also tried lowering the trigger point for the WOT using Olafu's tables, has worked as it now seems to click to WOT earlier but no change in the tracing issue.
Have you change the 'Table of tables' addressing, perhaps WOT address has been changed to part throttle address?
If the cell hit tracing seems to disappear from all of the fuel tables, idle, PT & WOT despite WOT protocol perhaps there is a problem with an input sensor or the DME has recognized something is unplugged.
When I deleted my idle air control valve the Idle control tables wouldn't come live or respond to tuning. The car idled, and idled smooth but drew it's data from an unknown source/table. I ended up simulating a load on the IAC wires by installing LED's and then the idle tables come live and would cell hit trace.
Hairyscreech
No, this one has been tuned up from a stock bin to avoid any cumulative errors, I don't think there is anything up on the ToT front.
I did wonder if it was a TPS issue so plugged the car in to INPA and checked that INPA gave the correct TPS signal and clicked to WOT at ~70% throttle.
It was all ok on that front and working fine in INPA so I think it is going to WOT but just not showing it on the table.
Could there be something up with my tunerpro config or is it possible this old pentium 4 toshiba is not fast enough to show the WOT table tracing perhaps?
Would be a shame as its a tough metal cased unit and the battery lasts ~6 hours and a couple of days on stand by. (hence why I am using it instead of my good laptop).
WOT tables was blocked by some faults or some special conditions. I can't remember, but maybe vehicle speed sensor? cam sensor? I don't know why, but something discrepancy happened. WOT was recognized by TPS, but wot tables was not in use. Also, for a while from engine start, there is no any WOT tables in use..?
Hairyscreech
Interesting, ok, VSS might be a culprit, The VSS plug on most E30s has long expired and gives intermittent connection, very occasionally I get the typical E30 speedo waving. I will start there.
It looks like it may be worth me spending some time confirming all of the sensors are consistent and withing their book values. They all seem to function and no codes are thrown but that does not mean they are correct.
Hairyscreech
I have been doing some work with the load calculation in the ECU and can now confirm exactly how it works:
Load formulae: Tl = Q/(n*K)
Tl - load [ms]
Q - airmass [kg/h]
n - rpm [1/min]
K - constant [kg/h*min/ms] reciprocal, factor=400
Let for example at full load we have:
Q=120g/sec -> 432 kg/h
n = 5000
K = 0.012
Load = 432/5000*0.012 = 7.2 ms
K = 1/K value in the bin *400.
Assuming the 413 K value is A9D6 (43726) then the constant is 1/43726 * 400 = 0.0091479
I think this is done like this to be able to get the best resolution possible for K/the K value.
The K value is not an abstract value, we should be able to calculate it.
If the load calculation is as above then assuming 100% VE at 1000RPM a B25 would consume:
1000/2*2.5=1250L/min
*60=75000 L/Hour
/1000 *1.225= 98.175Kg/Hour
So: 98.175/(1000*0.0091479) = 10.04ms of load, or theoretical pulse width.
Fuel for stoich= 98.175/14.7=~6.25Kg fuel
Bosch use N-heptane as the reference fuel @ 684Kg/M^3 density.
166cc/min / 60=2.7666cc/sec
/1000= 0.0027666cc/ms
*10.04=0.02777cc/rev/injector
*6= 0.1666cc/rev
*1000=166.6cc/min
*60= 9999.59cc/hour
/1000 = 9.99959L/hour
/1000 = 0.00999599 M^3/Hour
*684 = 6.839Kg/Hour
So if we want the 6.25kg/hour ideal:
Reversing the calculations up to the point of cc/rev/injectors gives us: 0.025382cc/rev/injector
*1000*60 = 1522.90
/166=9.1741 ms
So:
91.875/(1000*9.1741) = ideal constant = 0.0100014
/400 = 0.0000250035
1/0.0000250035 = 39994 or 9C3A
Now this begs the question why BMW are not using an ideal value for the injector constant, have they offset the values for differences in temperature?
If the assumption was made that the injectors run at ~50 deg C then the density would be more like 630kg/M^3 and the stock K value would give about 6.28Kg/H fuel delivery!
This would not be an invalid assumption as the injectors are mounted next to the head @~100DegC and are cooled by air and fuel flow that could already be around 30 DegC. If you have touched an M20 manifold on a warmed up engine then you know how hot they get, the injectors must be similar.
This raises the question if the believed injector constants are actually a little more subtle and require adjustment to suit engine size as well as injector size as they are a function of the theoretical MS pulse width that is needed to maintain stoichiometric ratio for a theoretical 100VE.
This brings me to the next point, I did say before that tuning the K value might not be the best way to do things considering what alpine did. However I think that this may be in error.
All the BMW produced BINs have a different K value even when they have the same injectors, they are also all within a similar value range.
I believe this K value should be used as both a tuning factor for adjustment of injector size and engine size to attempt to maintain an ideal VE correction factor of 128 for the part throttle tables.
Tl - load [ms]
Q - airmass [kg/h]
n - rpm [1/min]
n = 5000
K = 0.012
*60=75000 L/Hour
*6= 0.1666cc/rev
*1000=166.6cc/min
*60= 9999.59cc/hour
*684 = 6.839Kg/Hour
*1000*60 = 1522.90
/166=9.1741 ms
So:
/400 = 0.0000250035
WOT acceleration problems
M50B25TU, 240/240 cams, open loop, rest stock.
Is there somewhere positive deltaRPM fuel correction factor?
AFR is very good when engine is under max load and constant rpm, but rapid acceleration at high load goes very lean. Error is multiplied as higher is rate of acceleration.
As an example: constant rpm wot is 12.8-13 AFR, but 5 seconds wot dyno run from 3000 to 7000rpm AFR is 14-15.
Any help?
Thanks.
Other notes:
ECU does individual load/rpm knock correction map for each cylinder. It's stored somewhere in SRAM.
I did some tests.
- Set knock control load threshold to "0", so knock control is always "armed".
- RPM 3000, about mid load.
- Set whole 1. cylinder knock threshold table to "0"
- 1. cylinder timing is retarded by "fake knock". 1. cylinder misfiring.
- Set knock control load threshold to 254 and then let engine idle.
- Engine is idling smooth, no misfiring.
- Set all knock settings to "factory values"
- Then, when engine reaches about 3000rpm at mid load, and knock control load threshold is reached, 1. cylinder will misfiring by retarded ignition.
There is no knock, so, timing starts to rise to no-knock values. In few seconds there is no misfiring, and advance is back in normal value.
Findings:
- ECU will remember, if knock was detected in some conditions. Timing will not return, if conditions are not similar as knock has occured.
- IMO, In tuning, knock control load threshold is good to set to 254, or disable knock control by something way else. But knock must be controlled by other ways.
Any help?
Thanks.
Other notes:
I did some tests.
Findings:
I think such same way: D5 and D6 are 8bit load values, D5 filtered and D6 raw, but only 8bit. So, max. load value must be lower than 255(dec) but still as great as possible. Low max. load value reduces resolution. "K" is used to fit load in 0-255 scale.Hairyscreech wrote:I believe this K value should be used as both a tuning factor for adjustment of injector size and engine size to attempt to maintain an ideal VE correction factor of 128 for the part throttle tables.
Olafu: for your wot problems, the same thing happend To me in lower proprtions (between 1/1.5+ on afr on first and second gear acceleration).
I almost solved the problem by rising values in the last column of "acceleration enrichment quantity".
I dont know if its the best solution but it worked for me. I have a light riche spike when I press throttle on 5th gear but its not really embarassing, something like -0.5 on afr for a second.
Hairyscreech
I was actually getting similar up until this weekend, I have been struggling to get the acceleration enrichment right for the M20 and first changed the "0xDC21 D0*D5 4x4 Acceleration enrichment quantity by RPM and LOAD" to reflect the equivalent in the 173 maps and this had some effect but not enough, I then tried upping the acceleration fuel globally by adding to the last two columns of the "0xDC37 D7 4x1 Coolant temperature correction for accel enrich quantity" table, this had the expected global effect of upping the fueling at all points in the acceleration but I still found that I was too lean up top.
After a few runs on Saturday I noticed that I was staying rich as long as I held the throttle down from low load and RPM all the way through, if I lifted a little and reapplied the throttle I would go back towards lean for acceleration.
That made me wonder if there is a table effecting the amount of enrichment you get depending on the load and RPM you are at when you trigger the enrichment.
I think this table is what we have labeled as "0xDC63 D0xD7 4x4: Acceleration enrichment delta LOAD attenuation".
I reduced the numbers at higher RPM and loads and it was like a different car after, I was seeing down to 12:1 at higher RPM and loads instead of the ~14.2:1 I was seeing.
I need to do some more digging to find out how this truly works but this might help.
Triangulé
Greenday694
I thank you guys for all your hard work I've been following this post religiously. I have definitely learned a lot. but not enough to be able to really contribute anything solid. I was able to use a lot of your knowledge to tune a couple of my friends modified na E36s and 1 low boost turbo setup. But no success on my own car. I've tried a bunch of combinations raising and lowering different values trying to get my car to run as if stock off of boost steady cruise and idle yet at the same time at 1.5 bar of Boost give me enough fuel. I have to set everything to the almost opposite extremes. Drop everything so that it will idle and low RPM Cruise and then raise everything up on the higher RPMs and boost. so I guess my question is, is this DME capable of doing what I'm asking of it? Thax
in Failure there can be lessons . in perseverance there can be results.
Anyone hear about Daqarta..?
Interesting software. It spits crank and cam sensor signals out from PC sound card.
http://www.daqarta.com/dw_0okk.htm
I didn't run any tests yet with this software, but if you want to run your ecu on the table, without engine, this will help you.
I'm very curious to see how square wave camshaft signal comes out from sound card.
Hairyscreech
Nope, but I guess I have now
A bench test ECU might be the final destination of the ECU in the car at the moment as I have a RusEFI unit to go into the car once I have worked a few things out.
If the square wave is not very good then it would be trivial to send that signal to an arduino and have it toggle a pin high/low to get a cleaner signal.
Given the Motronic cam signal is only one on/off pulse every 2 rpm I would have expected it to be ok?
Re: M3.3.1 motronic (413 and 506) tuning and XDF update?
Hi all,
Does someone knows unit and factor for datas in dwell time table? I will soon use some "high performance " coilpacks for my turbo setup, and will have To tune this table for the new coilpacks..
Hairyscreech
I have in my notes file courtesy of our man in Finland:
"actually timing table for primary current switching on before desired ignition event, and same x*0.75 conversion works with it.
if you want to calculate new dwell table for different coils, correct formula seems to be (this includes all, no need to conversion): Actual RPM divided by 125 and then multiplied by desired dwell in milliseconds.
DWELL_TABLE_VALUE = RPM / 125 * primary_ms
And different direction: primary_ms = DWELL_TABLE_VALUE * 125 / RPM. "
Nice !
I didn't understand why raw values were increasing with rpm...
With the good equation things are way better.
Thank you very much !
Trying to understand how to rescale loadaxis after changing K.value for bigger injectors.
Havde don scaling for injectors and Voltage offsets and started up car,adjusted fuelsmaps so car is running pretty smooth.
But when I trace in maps with load it only reaches about half scale on load axis.
Have read here and everywhere for our to find a solution but I´m stuck.
Also tried to rescale the coluom labels for a lower load but that didnt help.
Is there any constant relating to load you can adjust,like K-value for injectors?
I´m realizing this is more advanced and complicated than I thought...
To adjust and get car starting cold as warm was the easy part...
Would appreciate some help!
Triangulé
please read my thread, olafu and i have explain how to do it.
Hi all,
recently swapped my E36 with a V8 M62, using a 404 DME with the XDF made by MYKK (huge thanks to him for this work).
Did some tests and I find 2 new tables that could be interesting, and since M3.3 and m3.3.1 are very similar I think it can be easy to find in 413/506.
Adresses are for beginnig of datas.
INDIVIDUAL CYLINDER FUEL CORRECTION
8x1 table at 0xC108, in the same zone that injector constant, rev limiter and others. Whole table at 128. Bigger values on the wole table make AFR richer, lower values make AFR leaner, at all RPM/loads, I think its a multiplicative correction factor, and it could be interesting for "bank correction". I displayed it as a table but can also be displayed as a scalar for each cylinder.
CRANKING FUEL ENRICHEMENT
4x1 table at 0xC897 ECT dependant, traced only while cranking. Just before "cranking fuel table" at 0xC8A8. I'm running E85 and bigger values in this table are very effective for cold start tuning.
mathematique facile
Hope this can help someone
mathematique facile
I think I found the same in a 413/623 bin:
Individual cylinder correction at 0xD0FA ? There is 8 values at 128, but maybe just 6 are used?
Cranking fuel enrichement at 0xDB93, a 5x1 table with ECT as descriptor, very close of cranking fuel table, scaling and datas are coherent with what I have in the 404.
Yes, D0FA is individual fuel trim. Last two bytes are reserved for 7th and 8th cylinder. And also cranking fuel CLT correction seems allright. In 0xD6D6 is temperature dependent RPM table for switching from cranking mode to normal running.Evil wrote: ↑Wed Dec 02, 2020 6:49 am I think I found the same in a 413/623 bin:
There is three cranking fuel tables In 623.bin: descriptors D7 (CLT) D9 (????) and D0 (RPM) and they are multiplied by each other.
*corrected D7 (RPM) to D7 (CLT)
Good to see I did no mistake
Thanks for the RPM switch, I found it in 404dme too.
Looks like this D9 is somekind of injection/ignition event counter or something like it. D9 starts from 0 and it counts to 255 in about 30 seconds@1000rpm and in 10 seconds @ 3000rpm... Doesn't roll over. It stays on 255 when it reaches it.
You may be right, on some others versions of Motronic there is a descriptor known as "number of engines rotations" (on MP3.2 IIRC), but it can be an ignition events counter. Unfortunately, function of the tables related to this descriptor were unknown on MP3.2
Thats probably some kind of flooding protection when cranking takes too long?
On the same subject, I found the cranking ignition table, which must be at 0xDCBE in 413
Re: olafu VIN2HEX
I'd like an award for most useless contribution for actual tuning, I think I have it. I need to confirm with more VIN/HEX code pairs but I think I have the cipher figured out.olafu wrote: ↑Wed Jan 03, 2018 7:35 am VIN code, date of manufacturing and some other information is located at 0xFEBE. INPA can show it clear, but it's not in ASCII format in BIN... And it's not directly written, it's splitted in "blocks" or something. Can somebody explain how that code can be translated to VIN? :D
VIN's first letter is located at 0xFEBE: (in dec:) 0=0, 9=9, 10=A and 32=W, 33=X and so on. But that works only with first letter. Third letter comes next, then 4th and 5th, but i didn't do more research.
There are a bunch of apps that do this but none say HOW. I can only do the VIN. I do not know the other data now. I do not have INPA or other soft setup to read a car. Only BINs.
The count as you described is used on odd characters(char1,char3,etc) in the VIN. The evens are masked with carefully picked substitutes that have a pattern. The VIN is 17 characters put into 13 bytes. Which means compression of the data or overlap. On the up side 13 bytes has has 26 characters to play with.
The first VIN character is the freebie as you said, THANK YOU(for everything in every thread not just this). There is no overlap of data to handle, its always the results of a HEX count to 23H/35decimal. All as you said.
Gets tricky from here on. 2nd VIN character is substituted with 1 byte from the associated mask. 3rd VIN character uses the Hex count. The 2nd and 3rd characters Hex that is 2 bytes is overlapped by 1 bit. The overlap is added? Shifted?(I'm not a CS so I will be lucky if I used bit and byte correct in this post).
The overlap and addition(?) continues to the end 2-3 overlap, 4-5, 6-7, etc. VIN 1st char no compression 1 char = 1 byte. Rest 16 chars = 12 bytes = 16bytes-4bytes saved by overlapping data. 1+12 gets the VIN in 13bytes
Code: Select all
hex mask list
00 00 0
01 04 1
02 08 2
03 0C 3
04 10 4
05 14 5
06 18 6
07 1C 7
08 20 8
09 24 9
0A 28 A
0B 2C B
0C 30 C
0D 34 D
0E 38 E
0F 3C F
10 40 G
11 44 H
12 48 I
13 4C J
14 50 K
15 54 L
16 58 M
17 5C N
18 60 O
19 64 P
1A 68 Q
1B 6C R
1C 70 S
1D 74 T
1E 78 U
1F 7C V
20 80 W
21 84 X
22 88 Y
23 8C Zrelevant code from the repo I think.
Code: Select all
# Make the hex output more readable
sub formathex($) {
my $hexStr = shift();
my $formatted;
foreach (my $key = 0; $key < length($hexStr); $key++) {
$formatted .= (substr($hexStr, $key, 2) . ' ') unless ($key % 2);
$formatted =~ s/^0x//ig;
return ($formatted);
sub VINtoHex ($) {
my $VIN = shift();
my $hex;
for (my $i = 1; $i <= length($VIN); $i++) {
$hex += $charArr{substr(uc($VIN), -$i, 1)} * 0x40**($i-1);
return ($hex);
sub hexToVIN ($) {
my $hex = shift();
my $VIN;
my %numArr = reverse(%charArr);
for (my $i = 0x10; $i >= 0; $i--) {
my $j = $hex / 0x40**($i);
$hex -= $j * 0x40**($i);
$VIN .= ($numArr{$j});
return (uc($VIN));- Attachments
- Spreadsheet to do the work. When proven will go public.
- BMW Motronic3_3_1 VIN HEX.PNG (97.52 KiB) Viewed 227277 times
I've been plugging away with research. I got into the rabbit hole of BMW TIS and found that with a MoDic tool or similar official BMW tool they could plug into the diag port and write to the eprom to update it is some cases.... Which means they is some area of the chip you can write too that will override some part of the original code. That's an interesting thing to know when we talk about extending and moving maps to unused space.
Chip replacements could also come blank and the MoDic tool would plug into the diag port and program the chip through the DME.... So the MoDic+DME on a M3.3.1 car could burn a chip. That would be fun to play with. I'll get the document numbers and post the them.
Also some handy info on what some of the numbers on the DME stickers mean/the meaning of some of the numbers related to labeling that is also in the data on the eprom.
I've been avoiding IDA for about 15years of following 413/506 DME work but it might be just about time to finally commit to opening that pandoras box.
Have been collecting every stock and mod bin I can find on the net and comparing byte by byte which uncovers some small details of interest and methods used by different people to tune.
I'm building up to the point I think I could make a HEX file builder in MS Excel but, I'd like it if it was on Google sheets better. Easier to share and work on together...even if it's just me too. Considering GitHub for the project again for open access to input.
I may just keep may M50B25TU for this.
Continuing the work on the XDF files here.
https://github.com/NomecOne/BMW-DME-M3.3.1/
Baltica
Hello. I have been following the M3.3.1 motronic topic for a long time. My car is 525i 95 413red 623soft camshaft's 9.7/240+Ostrich2.0+wideboard sensor. But I have little experience in tuning, although in my city people say the opposite. This is the first post here, what else can be improved in bin? I edited your XDF < changed the version from 1.80 to 1.60> otherwise it would not open. I will be glad to develop this forum.
Baltica
Hi. It looks like the tables d5e6, d63a, d68c, d6ae represent the fuel injection phase. The values for PT and WOT. The values in the table are the intake camshaft rotation angle, the camshaft sensor signal is used.
I got the idea to change these tables when I found out how one tuner was welding metal onto the sensor wheel. I thought it could be done in bin.
Nomecone thank you very much for your XDF. Good job.
I think cam sensor is polled, not making interrupt. So the injection timing is calculated from crank position. If someone was welded metal to cam trigger wheel, i think it's for adapt non vanos intake camshaft to suit it for vanos ecu. I've been done two times this mod to fit nv cam in vanos engine. But there is also easier way: use m50b20nv cam trigger wheel - it fits on to m50b25nv cam and works fine. M50b25nv intake cam with it's own trigger wheel doesn't work with vanos ecu.
Thanks for nomecone, nice to see there is someone who is interested to do work with this ecu
I'm back at it. Continuing to put even the unknown values into my xdf. I want to put everything in. When we figure out what it is we can rename it and put a description.
Also if anyone uses the xdf from my GitHub and finds mistake please post about it and/or write an issue on the xdfs page on GitHub.
These are the table locations you speak of. D0 axis is RPM and My notes say ****edit update D6 is raw loadBaltica wrote: ↑Thu Oct 10, 2024 12:57 pm Hi. It looks like the tables d5e6, d63a, d68c, d6ae represent the fuel injection phase. The values for PT and WOT. The values in the table are the intake camshaft rotation angle, the camshaft sensor signal is used.
Baltica
To make the injection later I need to increase the values, right?
Baltica
I noticed different rpm axes for vanos activation in 623 and 715. At high RPM in 715 vanos stays advanced a bit longer
Baltica
Re:
olafu wrote: ↑Sun Nov 26, 2017 10:44 am That's some last information for 413/506:
- Explanation for weird looking ignition dwell table - that's actually timing table for primary current switching on before desired ignition event, and same x*0.75 conversion works with it.
So, simply, if you want to calculate new dwell table for different coils, correct formula seems to be (this includes all, no need to conversion): Actual RPM divided by 125 and then multiplied by desired dwell in milliseconds.
- Injector timing tables: conversion factor seems to be about or exactly 3.
Some tests:
TABLE_VALUE = 200 - Injection pulse ends at 90 ATDC (firing cycle)
TABLE_VALUE = 233 - Injection pulse ends at TDC (firing cycle)
TABLE_VALUE = 255 - Injection pulse ends at 67.5 BTDC (firing cycle)
Those things must to be check with running engine... But .. Why they aren't right?![]()
