16146299 ADS file
pallemang
16146299 ADS file
Post by pallemang »
Iam all new to tunerpro RT but I got it down for the most part.
I have a 92 Chevy 350 TBI with the 16146299 pcm. I currently put in new 355ci and its been running good for the most part but I have a few problems with the IAC and engine RPM after its warmed up. It doesn't like to idle down after you accerate. I have replaced parts and its not mechanical problem as i can tell.
Iam looing for the ads file for tunerpro. I have looked everywhere that I know of. All the links on tunerpro, moates, and diy-efi.org. I currently have the following files (16146299.ecu, 16146299.xdf, awlc7710.bin )
Is there a way to import/exstract this ads file from other files?? Just looking for some good knowledge and know how.
Iam was thinking about swapping out the 16146299 for the 1227747 which iam told/read that is 100% compatable. Which has alot of tuning time behind, which is easier to find.
I believe the $99 mask uses a similar datastream to other common TBI trucks. You might try the $42 (7747) definition and see if it works. I'd bet that it does.
pallemang
Post by pallemang »
Yes i have tried the 7747 ads files. I have also tried several others. This is the " little project" that I did over the weekend .
I have the 16146299. I was playing with WinALDL when I noticed that the 16144288 gave the correct raw data and valves. So found all the computers that matched.
153 ($99) 16146299 2732 $D000 $D004 $D002:$D003 AWHD, AWLC
154 ($9A) 16156480 2732 $D000 $D004 $????:$????
154 ($9A) 16196396 2732 $D000 $D004 $D002:$D003
160 ($A0) 16144288 2732 $D000 $D004 $D002:$D003 AWHH
(info was found at http://www.cruzers.com/~ludis/idxref.html)
Nothing works liked normal. Just any idea would be nice. Thanks!
