eprom programmer
calliboy
eprom programmer
Post by calliboy »
HI... I've got a top2004 usb programmer...Do you know it's right to work with Tunerpro in read&write mode??? :D
TunerPro currently only supports the BURN1 from moates.net.
Post by Six_Shooter »
If your programmer has it's own software you can still use TP to tune with, then save the file, and import it into the buffer of your programmer software to program the E/EPROM.
I use a Willems dual power programmer this way.
