I'm having a hard time with the TPS % setting, but will look at that later, when I get connected to the truck again.
What I have working or what seems to work pretty closly to what I think should be proper is MAP Kpa, since all table values are defined by Kpa, not MAP voltage.
I used operation of Multiply, factor of .4 and offset of 0. I didn't do any math for the factor, since I'm still not sure how to calculate this, I just tried a few different values until I found one that looks right. I have a feeling that the value would be 0.3921569, since that's what Mark said to use for TPS percentage, that would have a range of 0 to 100%. This will work for 1 BAR MAP sensors, I'll have to figure out a value for 2 and 3 BAR MAP sensors.
I've been using a datalog file to view and watch the new gauge as compared to the original volts based MAP gauge.
What have you guys added, changed, or played with?
