compare xdf
845motorsports
compare xdf
Is there any way to compare xdf say you have 2 for the same config and you want to copy stuff over .. it would be super awesome if there was something like the bin compare where you can load both up and can easily copy tables over even if you have to place them in the right folder after it would be SOO much easier then doing the work by hand
Re: compare xdf
This is not currently possible. Solving this would not be straightforward. The best you can do today is to open a second instance of TunerPro, and load the second XDF in the second instance.
