Hey there, thanks for caring enough to click on my post! First off, please repost if there is a better spot on this forum relative to my questions. I'm trying to save the little hair I have left by coming directly to the experts here. I am just putting the finishing touches on the mechanical aspects of my Express Van Project and need to start gathering info for the software side. Here is the rundown on my project.
I own a 1996 Chevy Express 1500 CONVERSION Van in which my family uses for long road trips or group outings. It has the 305 4l60 drivetrain. About a year ago the rear main seal began leaking. Rather than going through the work of fixing it I decided I'd rather upgrade the drivetrain to a 350 4l80 setup so I can have a more robust drivetrain. I added some rear main seal stop leak which helped slow the leak and began my search for a doner. Well I found a great deal on an 1997 Chevy Express 2500 Basic SERVICE/WORK Van with the desired drivetrain. After weighing the pos/neg between chassis differences I ended up swapping the entire chassis over. Long story short, I've completely rebuilt the 5.7 l31 with a stage one camshaft, Hooker Cast Exhaust Manifolds, EFI Connection 24x Kit (https://www.eficonnection.com/home/prod ... istributor), Coil Near Plug Conversion.
I have done the 0411 swap to control the whole shabang. Initially was thinking of using the HP Tuners platform for mapping but it is far too costly in my opinion for a single project use. That is when a came across the TunerPro software. Seems exactly what I need. I have downloaded the latest RT version but have not registered yet as it recommends not doing until verification of successful interface. Also, I have downloaded the latest version of LS Droid for Windows and just received my OBDX Pro VX Cable.
Questions I have:
1. What is my next step, can I just download the current .bin from the 0411 to see what I have or do I need to download the definitions first. I think I remember having to download the definitions first when I did something very similar to this with for my Subaru w/ romraider and ecuFlash. Lost a lot of hair on that one through the learning process but hopefully that experience will largely apply to this. I believe that in that case the definition file I downloaded contained pretty mush all the Subaru models available at the time. Not a single vehicle specific file. So far I have seen conflicting info on this.
2. What OS? I read somewhere that it is best to Flash the most recent OS onto the PCM regardless of the year. Obviously I haven't hooked the computer up to the van yet so I have no idea what vehicle it came out of. It was however being advertised as a 2001-2002 PCM ( I guess this means it is a P01 PCM? https://www.ebay.com/itm/187035941377 ). Searching on the TunerPro site itself I did not see an obvious .bin or .ads file that matches what I think I need originating from an 01+ Chevy let alone model specific. I many options here
( https://github.com/BoredTruckOwner/LS_B ... Repository ) but not sure which is the one for me. If I were to find the correct .bin and .ads files for an 01 Chevy Express 2500 5.7 4l80e would the correct operating system not come with it? Not sure where to start here. The van is still Drive by Cable by the way and I have no intention of going DBW so maybe the OS is moot?
Thanks in advance for any help you can provide and have a great day!!
Express Van TunerProRT v5 Definitions Help
FattyBlaster6
