I've been messing around with this for a while and can't seem to successfully datalog the car. Would someone please outline the procedure for me? And/or is there a official Tunerpro RT guide that I don't know about? Thanks
(the car is a 1994 Corvette LT1 ECM: 161813333)
How to DataLog on Tunerpro RT - 94 Corvette LT1 (161813333)
thatpilotguy
Mauropears
Re: How to DataLog on Tunerpro RT - 94 Corvette LT1 (161813333)
Make sure you’ve got the correct ADX file for your ECM (16181333) and that TunerPro RT is set to the right COM port. Also check your cable connection. There are a few guides floating around, but I recommend checking Gearhead-EFI forums – they’ve got solid info specific to the LT1 setup
