Table Opens Larger Than Visible Window
bubba2533
Post by bubba2533 »
Hi,
I don't think this was intended so I am putting it in the bug area, but I don't know for sure.
When opening a table that is larger in width than what is available in the screen the table is hidden and there is no scroll wheel visible to go to the cells.
In a vertical example the scroll is shown but it does't allow you to get to the last rows in the table. You can move the table to access the hidden cells but it is quite annoying.
I've attached a couple images to try and how the issues.
Branden
Screenshot 2024-09-12 at 8.12.50 PM.png (97.8 KiB) Viewed 30579 times
Screenshot 2024-09-12 at 8.25.43 PM.png (173.24 KiB) Viewed 30579 times
Re: Table Opens Larger Than Visible Window
The workspace itself should show its own scroll bar in these situations to allow you to scroll to the edges of the table editor itself. Your screenshots are cut off.
bubba2533
Post by bubba2533 »
Ok, I don't know how I missed that.
It doesn't seem like the most intuitive way to get to the extent of a table. It seems like the workspace should limit the table to what is visible and then only one scroll bar is needed to reach the whole table.
