Group Maps When Using Difference Tool
tightmopedman9
Post by tightmopedman9 »
Currently, when using the difference tool you'll see every byte that is different between files. This means that if an entire map is different between files, you'll see multiple entries for that map. For files with lots of differences, this can make scrolling through everything quite time consuming. It would be awesome if the default arrangement was only one entry per unique map. There could be a '+' next to the map name which would then expand it, allowing you to see all the differences.
Re: Group Maps When Using Difference Tool
Yes, this is on my list of things to do. Thanks!
