Volvo M4.4 data logging with Tuner Pro
slklite
Post by slklite »
Hello everybody, I hope you're doing well !!!
I'd like some help logging a volvo V70r using Tuner Pro or any other method.
I can flash the ecu, no problem there, but I cant' get tuner pro to log data.
When I select different adx files availvable on the M44 wiki, only one allows me to connect but with data errors, hence no logging possible.
I was wondering if the problem was from the adx file, my computer, my cable or anything else.
Attached are the files I use.
Thank you.
V70R M4.4.zip
(93.96 KiB) Downloaded 763 times
