Bosch 402, 403, 413 red label xdf files
PingaDeSolda
Post by PingaDeSolda »
Hello everyone, I come here to kindly request definition files for the mentioned ecu's as the ones that are in tunerpro download section don't give the option for pops and bangs tunes aswell as other things like accel enrichment, if you have such xdf files please send them to ruinobrega3503@gmail.com
Thanks in advance.
nomecone
Re: Bosch 402, 403, 413 red label xdf files
Post by nomecone »
A lot of it is in how you tune what is there. Admittedly the files posted in the TunerPro download section are due for a refresh as they are not the latest. I'm working on changing that. Starting with the 413 red label.
If you search here there are some pop bang threads.
For the 40x ecus search for Mykk posted files. They may be over on bimmerforums.com he has a write up there I believe.
For the 413 the Hairyscreech thread is the most complete. There are links to his Dropbox in the thread. I also started continuing the work of Mykk/Hairyscreech/Olafu/all those before them.
I am about to make a new thread. The XDF is on GitHub so I can push updates and track changes.
https://github.com/NomecOne/BMW-DME-M3.3.1
Kurdish
Post by Kurdish »
Nice i work too on 400-402-403-404-405-413 how i can contact with you ? To make new update on old xdf for dme and i am update new tables on xdf for 405 and now i work on 400-402-403 .
altay51
Post by altay51 »
:D good job man +Rep 👍👍👍👍
