15.989 ms Injector limit?
I’m adjusting a fuel map for a friend’s Ducati and I went to add 6% to pulse duration with 1.06 multiply tool. Bin table shows correct values in red. When I go to save it, table is maxed out at said 15.989 ms duration!?! Values change when I save bin. What could be limiting the pulse duration? I know those injectors have a max pulse of 17ms and I was well below that value. Is there a cap applied in TunerPro? Could xdf have a limit? Bumping the fuel table’s column to 17 didn’t help. You can see flat spot at upper rpm’s in pic. What could be causing it to reset to said max upon saving bin? Thanks!
- 3C307DBE-CA5C-4CCC-B607-63EB8A320E86.png (73.26 KiB) Viewed 31278 times
Re: 15.989 ms Injector limit?
15.989 was original bin’s max value. It seems when I save changes, any value over this is changed. Strange?
