Rieju Aventura 500 Bosch MSE6.0 ecu tuning
New TunerPro bin definition files (xdf) for Rieju Aventura 500 with engine control unit Bosch MSE6.0 (US6.0).
Also available WinOLS OLSX mappack.
Price 60 euro.
Post: oldskulltuning.com/bosch-mse6-0-tunerpro-maps-for-atv-and-bikes
Available maps:
- Fuel: nominal lambda for component protection, lambda at WOT, target lambda at partial load, lambda during warm up by engine and coolant temperature, lambda limit for combustion, injection correction factor by effective injection time.
- Ignition: ignition advance-angle characteristic map, optimal ignition advance-angle map, ignition advance-angle correction by engine and coolant temperature.
- Idle: idle engine speed by engine temperature.
- Throttle: standardized air mass flow through throttle valve, desired throttle angle, throttle position sensor.
- Temperature: calculated exhaust gas temperature.
- Air Calculation: volumetric efficiency, map for calculation of nominal charge.
- RPM Limiter.
- Lambda deactivation.
ladygaga
Re: Rieju Aventura 500 Bosch MSE6.0 ecu tuning
Post by ladygaga »
Has anyone paired this with the WinOLS OLSX mappack? Curious if it’s worth the extra investment for finer control or if the XDF alone gets the job done for most tweaks.
2009 Buell XB12ss. sprunki retake
ladygaga wrote: Sun Mar 09, 2025 6:12 pm Has anyone paired this with the WinOLS OLSX mappack? Curious if it’s worth the extra investment for finer control or if the XDF alone gets the job done for most tweaks.
Hi there,
OLSX and XDF have the same engine maps.
michaelarrington
Post by michaelarrington »
Nice addition to the TunerPro XDF lineup for the Rieju Aventura 500 with Bosch MSE6.0!
anglerfish
Post by anglerfish »
Can you share more about your real-world experience using this XDF? Especially maps like “optimal ignition advance” or “lambda at WOT” do they provide any noticeable performance or fuel economy improvements?
