Address step on main table.
Asmo
Post by Asmo »
Hello, a simple but quite needed feature. While we get address stepping for x/y axis which can be set to negative values and reverse the order of the values there, we can't do that on the main table. Value size is one thing, order might be different on some tables/roms.
Re: Address step on main table.
This is Major Stride.
Asmo
Post by Asmo »
Mangus wrote: Mon Apr 08, 2024 6:30 am This is Major Stride.
Setting Major stride to -1 causes the app to crash, while setting "address step" to -1 within a row/column perfectly reverses the order.
In the example shown bellow i set the address step to -1 for the breakpoint column.
Thank you. I'll look into the issue.
