adding XDF items, 7730, 8D, AUJP
DENN_SHAH
Post by DENN_SHAH »
i want to add some items to my XDF relating to this post,
http://www.thirdgen.org/techboard/diy-p ... -aujp.html
i believe these are all flags/switches i want to add.
if i understand right, this is what i do for each of these items.
first i want to select insert new XDF item, next create a new flag/switch & give it a name such as TCC Coast Unlock, TCC Coast Unlock 1 & 2.
for 7E i give it the address of 610f & give it the bit number of 7.
now for E1, address of 6110 & bit 0.
lastly A2 would be 6111, bit 1.
is this right or am i doing it wrong?
It looks like you want to add three constants with hexidecimal as the output type, with the following addresses:
0x610F
0x6110
0x6111
To make the mod, change all three to 0. To set them back, set the first to 7E, second to E1, third to A2.
DENN_SHAH
Post by DENN_SHAH »
Thanks Mark, i'll do it & try it out in a day or so.
DENN_SHAH
Post by DENN_SHAH »
i put them in Constants/Scalers like you said.
one of the guys in the post said they got a CEL with them set at 00, i set them to 01 & it works good, no more unlock in decel :D
