Problem with Innovate LC2 in Tunerpro 5
Biller
Post by Biller »
emubt.adx.zip
(47.93 KiB) Downloaded 648 times
I have a problem with the integration of an innovate lc2 lambda sensor in tunerpro.
I have the adx file attached and the LC1 plugin, but unfortunately I can't get a connection.
It works via the logworks software from innovate.
I would like to put the innovate lc2 on data dash - WB AFR
Maybe you have an idea that will help me?
Thanks in advance for your effort.
Biller
Re: Problem with Innovate LC2 in Tunerpro 5
Post by Biller »
I got the innovative lambda display running in tunerpro using the Lc1 adx file.
but how can I tell the wb-lambda in another adx file to use usb serial port 6 in my case?
Virtually all data is transmitted via Bluetooth, I just want the serial port to be used for the WB-Lambda display in data dash.
thank you in advance for your help.
greetings Billy
