Bosch MSE8.0 ecu tuning using TunerPro XDF
New TunerPro bin definition files (xdf) series for CF Moto, Zontes and all other ATV and motorcycles with ecu Bosch MSE8.0.
Some of the supported ATV:
CF Moto CForce 450
CF Moto X4 450
CF Moto CForce 520
CF Moto X5 520
CF Moto Cforce 850
Some of the supported motorcycles:
Zontes D125
Zontes G1 125
Zontes GK125
Zontes M125
Zontes U1 125
Zontes U125
TunerPro available maps:
- Fuel: nominal lambda for component protection, lambda efficiency, map for start/post start enrichment factor, factor delta nominal lambda for component protection, fuel cut-off.
- Ignition: optimal ignition angle ignition advance-angle characteristic map, minimum ignition advance-angle map.
- Torque: conversion factor relative air charge to optimum torque, torque limitation by high exhaust temperature.
- Throttle: real mass flow over throttle valve, max throttle angle.
- Temperature: calculated exhaust temperature.
- Air Calculation: relative fresh air as function of manifold pressure.
- Cooling Fans: fans control.
- RPM Limiters: RPM limiter, RPM limiter (H+R), RPM limiter by temperature, maximum engine speed in case of error vehicle speed.
- Speed Limiter: speed limiter (H), speed limiter (L).
- Lambda Deactivation (beta).
Price 70 euro.
Post: https://oldskulltuning.com/bosch-mse8-0 ... -tunerpro/
