Polaris RZR 1.0L XP Bosch MG1CA007 ecu tuning and vmax off
Stage1 and Vmax off (speed limiter off) now available for new Polaris RZR 1.0L XP with ecu Bosch MG1CA007.
We are able to work on these engine maps:
Fuel: main lambda/afr maps.
Ignition: knock detection factor, optimal ignition angle, base ignition angle.
Torque: drivers behaviour, maximum engine torque.
Throttle: mass flow over throttle.
Temperature: calculated exhaust gas temperature.
Air Calculation: air quantity by pressure, calculation of nominal charge, engine load limiter.
RPM Limiter
Speed Limiter
Price 90 euro.
Post: https://oldskulltuning.com/polaris-rzr- ... ning-file/
