Tables become hardly editable after comparing bins in the latest Tunerpro
ngt
Post by ngt »
Continuing the aforementioned post here http://forum.tunerpro.net/viewtopic.php?t=6493
with the title "Table color changes to transparent after Table compare switching"
Besides the colouring issue, also, you can't mark an area of the map and change its values after you only click once to compare....
its certainly a bug intorduced with the latest revision.
I made a second thread so it gets more attention with a more proper title
Re: Tables become hardly editable after comparing bins in the latest Tunerpro
This is fixed for the next build, along with the issue in the other thread, as a result of the same change.
