Datalog export problems
scrappy
Post by scrappy »
When I export a datalog from tunerpro as a .CSV when I open it the datafields are empty. It just started doing this a couple of nights ago. I think I changed something to cause this but I can't figure out what it is. anybody have any ideas?
Are you sure the datalog isn't empty? If you play it normally (through TunerPro), do you see data as you'd expect?
scrappy
Post by scrappy »
Mangus wrote:Are you sure the datalog isn't empty? If you play it normally (through TunerPro), do you see data as you'd expect?
I just figured how to watch it in TP and there are 0 samples saved in the logs so there is nothing to export.
Sound like that's the problem. Are you able to monitor data actively in TunerPro?
scrappy
Post by scrappy »
The dash and values are working realtime. I Did something to cause this because it worked last week, but I haven't a clue what it was.
