Checksum update error GM P01 Bin edit
RCSBLSswap
Post by RCSBLSswap »
Tuner Pro Version 5.00.9322.00
Was able to flash 2 different archives into a module both with 12208332 SW. Extracted the BINs using LSDroid. Grabbed the correct XDF and loaded a BIN and the XDF in TunerPro. After making all my mods when trying to save I am getting "Error - One or more checksums could not be updated. Check Checksum addressing, etc, for validity". Any ideas? I googled this and searched the forum but came up empty with a solution that will work for me. I tried flashing anyways and nuked a controller, but was able to recover it with service tools and a stock archive. I extracted the BINs using LSdroid.
RCSBLSswap
Re: Checksum update error GM P01 Bin edit
If I go to Help: Plugins - Nothing is listed. I even reinstalled TunerPro with no change...DLL is in the c:/Documents/TnerPro Files/Plugins Folder...Running Windows 10...
babbit bearings
Post by babbit bearings »
Same for me the .dll is in the correct location, but is not listed in help => plug-ins
The P01 checksum plugin is written by a third party, you will need to contact them if there is an issue with it.
