The ability to set axis conversion per cell or at least set patterns
bradsm87
Post by bradsm87 »
If I want axis item 1 to be X*0.1, next item to to be X*0.2 etc., I need to create a separate table for that axis with per-cell conversions then link it. It would be great not to have to do that.
Re: The ability to set axis conversion per cell or at least set patterns
Thanks for the suggestion. Seems like a rare need, for which you have a solution. At the point where you're entering conversions for each cell, it's not much extra in overhead to simply create a table to link.
The next build will allow you to double click an axis value to open up a linked table for editing. In the future, I may also add inline editing of axis values for linked tables (the next build will have inline axis editing for internally defined axes).
