2014 Hyundai Accent & Modified ELM327
slapshot73
Hello everyone, first post here. I've searched and can't find the answer anywhere. My daughters car (as noted in title) recently had the check engine light come on. I'd like to read the codes and see what is causing it. I've got a modified Elm 327 that I use on my Ford vehicles with Forscan. I tried to use the adapter with Tuner Pro RT, but it doesn't seem to work. The program says "Hardware Not Detected," no matter what I try. Can anyone confirm two things for me? 1, will Tuner Pro RT work with the car and 2, will my adapter work? If I need an adapter, can you recommend one? Thanks!
