Remap ECU
scotintherock
Remap ECU
Post by scotintherock »
Very good site :D ..... a lot of good info....
I need some help to remap my Hyundai Accent ECU....i've a OBD2 interface (i connect with the K-Line....ISO/KPW protocol)..... i try with TunerPro RT, the software find a hardware and connect fine (status in hardware and ADLC is connected) buy i cannot rescue the BIN file in to my hard drive or see the hex tables........ there is something i'm doing wrong.....o just the TunerPro RT don't work with my ECU (Bosch ECU)
anyone knows some software to work with my car..... i know this is very hard question and hard to fine :cry: ....
I pretend to modify the tables of pressure (MAP, i've a MAP 2.5BAR Turbo), load and ignition....
Hyudai Accent 2005 1.6 16v Turbo
I'm not aware of any XDF (bin editor definitions) for your vehicle. TunerPro will not interface with the OBDII data stream.
