I am confused with the ECU files.
My car is Kit Car (Cobra replica) with a 305 Camaro engine from ?87 with a 1227165 ECM and the standard ABUT bin file. (Calif. With A/T) but I have installed a T5 NWC on it.
Well I want to change the BIN file and I found a ?32Bv001.ecu? file that I use.
This file gives me different figures for the FAN temp that when I use the ?6Ev010.ecu? this one is more detailed than the $32. (Temp for the same bin on $32 is 29F vs. 225 for the $6)
So my question is:
Witch one should I use?
Is the cold start injector the only difference between booths ECU?s?
Karel
