shindengen ECUs
Re: shindengen ECUs
first you will need hardware to interface the ecu and read out the stock binary
once you've read it out you will then need to find a disassembler for that ecu processor in order to read the code
you will then have to go through the code and figure out the algorithms in order to create a definition file for it
here is a brief description of the process for fords, same applies for all ecu's
http://www.efidynotuning.com/dis.htm
Re: shindengen ECUs
this is hảdware , use mcu upd 70d3577 /FG4
Re: shindengen ECUs
peter 62 ,, i sent messenger to u ,,inbox
Andre Chee
Re: shindengen ECUs
I have finish read this bin file
Re: shindengen ECUs
Can anyone show me which device to use to read this ecu shindengen bin file. Thank you so much
Re: shindengen ECUs
How to read ecu from backdoor pin? Do you have diagram circuit pin?
Cokie cokie
Re: shindengen ECUs
hubungi saya di Osatriadi@gmail.com untuk shindengen
Re: shindengen ECUs
Now, can write via k-linedecipha wrote: ↑Tue Aug 06, 2019 12:25 pm first you will need hardware to interface the ecu and read out the stock binary
