Slow opening "Edit parameter XDF info"
pauldaytona
Post by pauldaytona »
It started I think when I bought myself a 34"ultrawide monitor(3440x1440), mainly to be able to have multiple Tunerpro instances next to each other. With that I bought a new graphics card, Nvida gt1030 based because my internal video could't do the resolution.
Now all things work normal speed. Only opening the parameter property's to edit something takes until 8 seconds. I see the cpu going up. The graphics monitor shows low utilisation, normal because there is no 3d use. PC is latest w10 pro with 16Gb memory, ssd and 3550 I5.
All pretty annoying. editing xdf's makes a lot of use of opening these parameter window.
Re: Slow opening "Edit parameter XDF info"
I can't think of what could possibly affect that. When entering the edit mode, the data is already parsed and loaded, so there's not a lot happening on the TunerPro side.
Has your OS been updated lately?
pauldaytona
Well normal windows 10 updates. As it always gets them as they are there.
