lookup tables
mecanicus
lookup tables
Post by mecanicus »
Hi, I have configured a lookup table and have linked it to coolant temp.The "help" says I can see it on pressing the conversion tab.Where or what is that.
Can you show that on a picture please.
Re: lookup tables
After creating your lookup table, in an ADX Value, click on the conversion tab. You'll see a check box labeled "Send converted data to lookup table." Select that, and then select your lookup table from the drop list labeled "Lookup table."
mecanicus
Re: lookup tables
Post by mecanicus »
Which droplist to you speak of? I find the lookup tables only in edit adx.Thought i would see them when playing a log-file like dash, history and so on!
Can you post picture?
