Hi
I have a quick question.
I want to tune my 2016 Aprilia RS4 125 and Ive extracted te bin and have the XDF file as well
I changed the revlimiter by adding +1000rpms but when I want to mod the warm ignition map, new RPMs are not there. How can I add them because its not there automatically.
Thank you!
Tuningbeginner - please help
pauldaytona
Re: Tuningbeginner - please help
You mean that on the axes the revs don't go higher as you added that? They won't but the engine will rev higher, the ignition stays the same as the highest valuestarmo wrote:Hi
Thank you!
Paul thank you for your answer it seems that I have missed it
Yes I mean on the axes, when I increase the revlimiter, the revs on the axes dont autoadjust to the change
I made the rev limit increase but its no effect on the bike. Do I need to do a Throttle Position Sensor (TPS) reset maybe?
I dont think its TPS however becase the ECU cuts off at 10500rpm and I have increased it to 12000 (where 13000 is max)
THank you in advance
Basically I want to increase rev limiter a bit and maybe get out some more power.
I have turned off the Lambda 1+2 but I cannot increase (or add line) below default 11500 rpm
Also I dont have a clue then what to increase more i.e. the X axis and cant find any tutorial.
What do you think?
What do you think?
- RS4ORig.rar
- Original bin file
- (130.36 KiB) Downloaded 1223 times
- RS4_NoLambda_RevLimit1KPLUS.rar
- Modified bin file
- (130.38 KiB) Downloaded 1261 times
- MIUG3_Aprilia_RS4_125_CM227201_V1.00.rar
- XDF file
- (3.15 KiB) Downloaded 1165 times
I only turned off the lambda and changed max rpm
begginer as I am
If you make any changes, for my sake of education, can you please record screen so I can see what you can do and maybe upload on youtbe
I have seen one of your videos https://www.youtube.com/watch?v=NrTlLpkGUDI that one but it seems to me that you drew those points randomly or?
Regarding reading/writing on ECU thats no problem only tunerpro issue making a bin is for now.
Hello. how did you pick that out?
I've tried it a few times on the diagnostic plug.
but do not get connected to read.
or did you take the cables directly at the ecu?
I would be grateful for help.
Greetings from Germany
Hi
Your cable (or diag port) is probably bad. I only use diag port and works well with guzziutils and appropriate ECU reader. Depends also on which ECU your bike has
