microsoft visual c++ 20** redistributable packages
VesaII
Post by VesaII »
Hello
Installed a new instance of Win 7, which did not have that 'redistributable' package and cause of that i got lot of different announces of missing files when starting TunerPro
TunerPro do install 2017 version of package when installing it self, but is is not enough as running of TunerPro reguires several older packages to be installed before that. I begun with ver 2010 then 12, 13 and 15 and voila.
Now i know how to fix this, but it would have been nice if default package was enough.
Maybe you already are aware of this...
Br,
Me
Thanks for the report. TunerPro itself shouldn't rely on anything but the VS2017 runtime, but I'll verify and fix any references to older libraries.
You should also be sure that third-party plug-ins aren't the culprit, as they may require older runtimes.
