ms43 turbo
LSRmotorsports
ms43 turbo
hello, ive just gotten into this factory ecu tuning, I normally use standalones but this is a cheaper alternative I'm on a steep learning curve. This car is still using a maf, normally I'm using map readings to tune the tables ect, anyway ive found a proper xdf file for me to read the tables. and I have a good naturally aspirated bin to work off of. So I'm asking to those of you who have been using this software for a while, which tables am I needing to modify for this car to actually get into boost. Ive tried the basic injection timing, I have pulled timing off multiple timing tables, but it goes lean I'm assuming maxing out the maf tables. any help is much appricated.
