DME 403 SOFT 950 XDF
Here is my current XDF for DME 403:
https://www.catupload.com/download/dd96 ... a3567.html
Many things have been found thanks to the discussions we have on the 413/506 thread and the amazing work of Hairyscreech and Olafu (also Mykk who is very active on this thread)... So a HUGE thanks to them.
It is not 100% complete, some descriptors are still unknown (1C, C9, D1, D6), and many tables functions are still unknow, we can discuss here if some have infos for this DME . Anyway, ALL tables are listed.
I will update here all evolutions of this XDF.
Sounds right, D2 and D3 are the equivalent to the D5 and D6 pairing in M3.3.1 everything I have seen points to a very evolutionary approach to these ECUs, even across processor variations and engine architecture changes much of the process and programming philosophy is retained.Evil wrote:For temperatures i use X*0.75 - 48. Thats the formula Ive seen on many threads here, dont know if its 100% accurate.
Are you sure for D6 To be raw load?? There is no D5 in 403, and I think raw and dampered load are D3 and D2
Re: DME 403 SOFT 950 XDF
Hi DIY tuners,
Can someone help me to get the XDf file for 403, I can't download them for the links posted on this discussion.
thanks in advance.
thanks in advance.
Hi, can someone share a good bosch 403 xdf please?
this one is working for both 405 and 403
you should know how this ecu work before tuning dont just change numbers specialy rev limit donc just make it 7000 or 7200 it will be wrong
- 405-403 xdf.zip
- (2.37 KiB) Downloaded 1234 times
