how to define range for a value (A222.DS)
LittleNo
Post by LittleNo »
take a look at byte 27 in A222.DS - this value has to be devided; how do i have to set the range correctly that it shows the 0-100 %?
same question for byte 10 after the simplification to match the fields in TunerPro?
It's a byte, so it ranges from 0-255. 255/2.56 = 99.9 (%). You don't have to do anything. It's already set up.
by the way, X/2.56 is the same as X * 1/2.56 is the same as X * 0.390625.
LittleNo
Post by LittleNo »
that was what i thought
look how it shows this value in the monitors: http://www.lnoperformance.de/files/tp.jpg
the value itself seems to be correct, shows the position the throttle actually has
LittleNo
Post by LittleNo »
LittleNo
Post by LittleNo »
i played a bit with it, it does that with all values where it hast to do a divison - all others are ok
Set it to use multiplication (not division), with a factor of 0.390625.
