Longer ID string for default XDF
RedTop
Post by RedTop »
It seems it's only possible to use one byte as ID for the default XDF function. It would be great if you could use several successive bytes to assure that the correct XDF is used.
Re: Longer ID string for default XDF
RedTop wrote:It seems it's only possible to use one byte as ID for the default XDF function. It would be great if you could use several successive bytes to assure that the correct XDF is used.
Can you clarify what you mean by "ID for the default XDF function?"
