Working on a plugin
erich
Working on a plugin
Post by erich »
So the plugin I'm working on for data acquisition is having a curious call order from the app.
When I click on the "Acquire Data (Connect/Disconnect)" toolbar icon, the plugin InitializeHardware() method is called (as expected), followed by the SetTimeouts() method (that is also expected) then immediately followed by the ReleaseHardware() method (not expected at all!)
The Initializehardware() and SetTimeouts() methods both return S_OK, so I a little stumped at why Releasehardware() is called right away.
Any ideas?
Hi Eric,
Are you still having trouble with this? If so, I'll help you out in email (you're already in my inbox, I believe).
-M
