TunerPro unable to handle 8 bit data on RoadRunner
prj
Post by prj »
Trying to update a single 8 bit value fails with "Upload failed".
Data tracing on 8 bit maps results in "Error".
For 8 bit it only works if you select to upload whole maps and select a map that is 16 bit aligned and has an even number of values. If it has an odd number of values or is not 16 bit aligned upload also fails.
Currently I have resorted to using EmUtility, as EmUtility does not have this problem.
Re: TunerPro unable to handle 8 bit data on RoadRunner
prj wrote:Trying to update a single 8 bit value fails with "Upload failed".
What build? This was fixed a build or two ago.
prj
Post by prj »
8040, I guess time to upgrade.
Thanks.
