I am trying to get Tunerpro RT running on my Dell Laptop running Windows 2000. The program loads without issue. When I execute Tunerpro RT, I immediatelly get the following error msg;
C;\programfiles\tunerprort\tunerpro.exe is not a valid win 32 application
I checked the down load on a Windows xp pro desk top and it loads and runs well. I have tried to load Tunerpro RT 4 times on the laptop and always get the above error msg
Will Tunerpro RT run on a Laptop running windows 2000 ? Or is there something special I need to do to run this on windows 2000
Thank You
8Valve
Tunerpro RT and Windows 2000
I am using Tunerpro RT V5. Thanks for the information. Unless someone posts a way to make it run on Win 2000, I will Uninstall Win 2000 and install XP Pro SP3.robertisaar wrote:are you trying to use tunerpro V4 or V5? V5 is only officially supported on XP SP3 and later(though it has been made to work on XP SP2, that i know of).
The Older Dell Laptop is dedicated to this mission.
8Valve
