im thinking i already answered this via email for u but you can replace the m1.1 ecu with an m1.3 ecu. straight swap, unplug the 1.1 unit and plug in the 1.3 unit. you cant swap 1.1 and 1.3 chips about though, you can swap 1.1 chips for other 1.1 chips and 1.3 for other 1.3 though.
also M30B30 files can be interchanged with M30B35 as can M20B20 with M20B25 though ignition and fuel map values are slightly different but not so much that one file will not run on the others engine if that makes sense..
swapping internal eproms between DME 150 151 152 153 will get you working and also swapping the ECU to a DME 170 171 172 173 or even 179 will also work for you.
if this also does not make sense to you just send me your bin file and i will create an XDF for you.
