documentation means nothing if you just arent cut out for the job
im sure i could collect lots of files and documents if i ran a forum and took everyone elses files too but like i said i have a conscience. if you were in any way smart you would be changing your business ideas from quantity to quality, and maybe be honest and apologise to those you have betrayed.
i do not question that you do know a bit and you can use disassemblers like IDA pro but you think you are an expert in everything when you clearly are not. a good tuner knows that they do not know everything and the things they do not know they try to learn from others in return for helping them in areas they are not strong in, etc. you know.. two heads being better than one..
forgetting your "colourful" personality.. id nearly consider helping you with things in return for help in areas im not well versed in (disassembly in particular), however, trust is a hard thing to win back and the ball was left in your court some time ago. hell if you turned into a decent fella revlimit may even jump on the bandwagon. that would be 3 seperate skill sets and footing in 3 countries in business terms.. your never going to hit the bigtime rolling on your own dude, we all know this.. and dont assume i think ill be hitting the bigtime any time soon either, id need skilled help and alot more products/services than i offer now. only difference is im realistic in my view, rome wasnt built in a day nor was it built by one man on his own.
