Need Help with $8D ADX Value Equation
toliphint
Post by toliphint »
Would appreciate some help with understanding the correct conversion equation for a TunerPro v5 $8D Value
Injector BPW
Are both of the following the same? Have seen both used.
Packet Offset: 45 dec
Data Size: 16 bit
Equation: X * 0.000066 + 0.000000
Packet Offset: 44 dec
Data Size: 16 bit
Equation: X * 0.015259 + 0.000000
Thanks!
offset of 44 and X * 0.0152587890625 should be correct.
and offset of 45 would mix the LSB value of the BPW with the MSB value of the target AFR.
toliphint
Post by toliphint »
Thanks for the reply. After more research, I was incorrectly looking at 8d and 6e. The 45 offset is apparently for 6e (per 1277165_6E.ads).
