E85 Support.
SY-1193
E85 Support.
Post by SY-1193 »
Just a suggestion...
With a lot of people using E85 and other Ethanol added fuels there is a tuning issue with the varied amount of Ethanol in pump fuels. Other systems are incorporating an in tank sensor such as a GM in tank Ethanol sensor to vary based on the amount of Ethanol picked up by the sensor. I know that Big Stuff 3 is using some sort of setup for this is it possible with TunerPro?
I am running a '749 ECU with Code$59 this would be a great additiion if possible.
Post by Six_Shooter »
That is a code dependant option, nothing to do witn Tuner Pro itself. If Dig and the other authors want to impliment some E85 options they will have to be weitten into th $59 code.
yeah, this is in no way a Tunerpro issue, it's something that will be mask dependant.
as Six has said, talk to the Dig and the other code59 crew members about adding it in if you would like.
You should hit up the code $59 guys for this.
