how to create a definition file?
garyfink
Post by garyfink »
If there is no supported def file in you downloads section how do you create one. Can it be done with a moates emulator? I guess you guys call them a .xdf and how do you get that file extension.
Gary
EagleMark
Post by EagleMark »
What mask/ECM are you looking for? Your looking to make changes in bin file with XDF right? Do you have data aqcusition file ADX for it?
There is an TunerPr XDF/ADX lookup availble in excel format at:
http://www.gearhead-efi.com/Fuel-Inject ... files-here
garyfink
Post by garyfink »
I have a .bin file I bought but when I try to load it tunerpro tells me there is no .xdf loaded. Which is the calibration code for the pcm. Without it the software does not know how to handle the data.
As far as I can see there are no places on the internet to find these files so I need to know how to create one. Can it be done with a moates emulator?
garyfink
Post by garyfink »
the pcm number XLE4
CALIBRATION CODE FROM THE DOOR JAM IS 9DTA-AJ.
but that means nothing to me there is no info attached to that number.
Guess I need to kep digging.
EagleMark
Post by EagleMark »
Not every single car has been done, What kind of car?
EDIT: Ooops, just noticed this was in Ford section, I don't know much about them...
It looks like the ecu is from a diesel, strategy VHAE9.
To create a xdf you need to disassemble the code to figure out where (and what!) the parameters are. Once you have done that you can create your definition, see the TunerPro help section 'Editing Bin Definitions' on how to do this.
garyfink
Post by garyfink »
you're right it is from a diesel and man is that group tight on information.
somebody must be making a killing tuning diesels. Everything costs a million bucks.
garyfink
Post by garyfink »
ok I have the .bin so I can read it (if that's what you want to call it) but how do you decifer it?
You need to disassemble it, Bill Lawrence's disassembler can be found here http://autos.groups.yahoo.com/group/EEC ... r%20tools/
Zhivat
Post by Zhivat »
Hi guys,
I have same problem, I want to create definition file for my DELCO ECU with MULTEC M system, I have the BIN file... Can you suggest me where I can find the guys which can disassemble BIN file?
