Mark,
  I'm looking for a scanner to read the WB02 hack.  I've used Z69's AXCN bin for my P730, but  cant find a scanner to read the WB output.  Is there anyway to modify th ALDL outputs to output Line 37?
						WB 02 capability
edit
Its easy in TP to add an item to your ads file.
Open the ALDL setup screen, browse for your existing ads file if its not already loaded. Then click the "edit ALDL definition" button.
Select the "sensor" item above where you want to add it and click "insert".
Give it a name WB AFR or whatever you want to call it and in the box below it enter the address # 37. Do a Save, or save as..
Should display just fine
The WB patch output is 10 to 20:1 AFR and should just be set for multply factor of 1 with no offset.
Happy logging.
Happy logging.
