'91 corvette - anyone have the files needed?
mistaben
Post by mistaben »
Hi guys,
totally new to tuning thing, but I bought an APU1 and G1 socket adapater and some extra chipsets...
I am trying to get tunerproRT (i got the code to register it etc..) to work. and I am a little confused on where to start.
thanks to anyone that has the files i need.
for what it is worth... I am going from a 383 with stock everything but 24lb ford svo injectors...
to a 383 that is stock nothing (new heads cam and intake) and 30lb bosch 3's. I got it to start and run... I can even used datamaster to datalog... but I can't seem to figure out tunerproRT
tony
EagleMark
Post by EagleMark »
You need the XDF file to work on the chip and the ADX file to record data. They are specific to your ECM and most are listed here:
http://tunerpro.net/downloadBinDefs.htm
historystamp
Post by historystamp »
Here are some instructions for beginners!
http://www.ls1tech.com/forums/lt1-lt4-m ... orial.html
Go over to Mr. Toates or Aldl site and buy the appropriate cables.
http://www.moates.net/
http://www.aldlcable.com/
How to setup the dashboard in TunerPro RT.
http://forum.tunerpro.net/viewtopic.php ... =obdii+adx
Find your ECM in your car. Mine was to the right of the glove compartment. It's likely to be a silver box. Write down the number. I took a picture of the ECM number on the sticker. I could route the image to make reading the number easier.
Download BCC lookup.xls table from the Internet. It will provide you lots of related info on the ECM like platform and engine type code used in in identify the tables you need.
http://www.google.com/url?sa=t&rct=j&q= ... Lg&cad=rja
The xls file is somewhere on this site:
www.ihonlynorth.com
googling for BCC lookup.xls will file the file.
EagleMark
Post by EagleMark »
Pretty much all the files and bins are here:
http://www.gearhead-efi.com/gearhead-efi/
90 Corvette, is that an $8E? You need the number off your ECM and you can find all the info in one thread here:
http://www.gearhead-efi.com/Fuel-Inject ... ning-files
