3800 series II 1995 ecm
Having trouble with ALDL datastream.  Using 5B6.adx getting multiple errors within the data.  Numbers jump up and down sporadicly across all parameters.  Any ideas?
follow through:
acquisition
edit definition
commands
for every mode 1, message x reply, check out "body size", "payload offset" and "payload size".
body size should be payload size + payload offset + 1.
if necessary, modify all the ones you are monitoring, or just do them all, then save the definition, try logging again and see if it fixes the issue.
						acquisition
edit definition
commands
